HMS Alert by DST
While testfitting the aftmost knee I realised that it was too short. Or maybe I did something wrong on the stern assembly...
I thought I could hide that gap under the waterway but it will be visible (see the gap near the hanging knee)
So I had to make a new one. There was no more cherry left big enough for a knee or two for that matter so I had to cut it from a piece of pear. This is the closest wood I could find in terms of color matching. Once it's oiled it should match the color of the cherry enough to blend in with the rest of the model
This is the paper template
The part cut out and a first testfit
After several sanding and fitting it looks good
This completes all the lodging knees and on to glueing the ledges in place. Should be straightforward...
Thank You for Your interest
Nice recovery!
Yeah, that's what I thought, but only after the glue was set completely... of courseCautious
Don't have much time at the moment but I think I should be able to pull it off. If not I can always redo them.
One quick Photo of the actual stage: all knees and carlings glued in place. Some are a bit more out of a true straight line than I was imagining it to be but I'm still happy with the result.
Approaching perfection here my friend! So very well done!
I couldn't work much on the ship lately, just got tge hull out of the berth and started working on the stern timbers.
There are some huge gaps on the underside...
I had to fill those with pieces of cherry veneer:
The result is not great but better than having gaps...
Trying to handle that fragile part FL104... I swear it broke just by looking at it and trying to figure out how to install that thing.
Hi Dan,
In your photos there are pieces with notches in places where the garboard strake of planking should be. What are these called? I don't recall ever seeing pieces like this on contemporary drawings like the one below or contemporary models.
Thank you kindly for your help.
Hi Dan,
Hi Allan,
those are calles rising wood if I'm not mistaken. They are still oversized and need to be sanded flush with the frames.
They would be shaped from the timbers rising up on the keel to form the stem and stern and to make a platform to rest the cant frames on.
I'm not at home at the moment and can't verify but I'm sure someone can correct me if I'm wrong.
I thought that might be the case. I guess it was the angle of the photo that had me confused. Thanks for the clarification. Do you know when the steps changed to a continuous curve? I know it was already changed by about 1800 but not sure when the steps were eliminated.
I think I found the answer to my own question. Looking at a number of framing dispostion drawings, the stepped deadwood and rising wood changed about 1790. Couple contemporary drawings follow.,
Hi @AllanKP69 ,
that is a good question. I used for my reconstruction of the backbone of the Alert a curved deadwood. It fitted much better with the hull than a stepped curve.
Perhaps it's a little early, but a lot of imporevements were tested at smaller ships first before they were used for classified ship
