Thanks everybody
So after fixing the foremost parts of the deck clamps and temporarily fixing the aft parts I could check the length of all the beams. Only amidships the beams are too short, so maybe I sanded too much that area... but 1mm on either side?! I'm not sure....
Shaping the first beam. It is laborious to adapt it to the geometry of the frames but worth the effort. A tight fit always gives a sense of satisfaction and keeps You motivated to continue working.
I stole, or maybe borrowed, dockattners system to establish the centerline and thus keeping the beams centered across the length of the ship. Works really good:
While trying to adapt the middle section of the deck clamp the scarph joint broke off, of course. I had to reglue it several times, finally using CA glue and glued it in place.
The joint is not great and I tried to hide it with PVA and wood dust from sanding:
This is how it turned out:
Should be OK once the deck is installed I doubt it will be visible.
That's it for now, thank You for visiting
I agree, that would make fitting thise pieces way easier....I like it more, when the kit designer is making the beams on both sides maybe 1mm longer, (with the info in the manual that the modeler has to make the length adjustments equal on both sides....
I think that will be a good solution, even when it will be hidden by the waterway. But for stability alone it will be worth....I suppose you could scab on a little piece of wood on the ends of the beam...
