- Jan 10, 2022
Thank you very muchalso from my side congratulations for reaching this working step.
Bravo - and btw the result is looking very good![]()
A harmonious and beautiful structureRibs trimmed to their correct heights and spacers placed between to bring them into line. That's the frames just about complete apart from marking and cutting out the gun ports. The instructions show this to be the last step in the construction of the hull frames, so my next step will be to take the whole assembly out of the cradle to add the transom timbers. Then it will be ready for its final sanding and 2 coats of the wood finish that l mentioned earlier.
Thank you very much UwekBRAVO - Congratulations for reaching this working step
Looking very very good
Thank you very much my friendA harmonious and beautiful structure![]()
Thanks maartVery neat work Keef, always a rewarding moment to look for the first time at your hull free from its mould.
One remark it seems the hull is bending in at this point I would temporary fit an inside support to straigthen it until the deck beams are fitted.
View attachment 321655View attachment 321656
Thank you HeinrichVery good observation and excellent advice, @Maarten Maarten. Other than that, it looks superb! Well done, Keef!![]()
Thank you JimskyExcellent, Keef, a very good milestone to pass! Congrats!
I actually bought this ''building slip'' about 7 years ago. l believe it is from Billings Boats. lt is adjustable to fit any size hull. lt would be extremely easy to make one though. l could take some photos and give dimensions for the parts if you wishI like your temporary support frame, can you provide information or plans on how you built it, we may all be able to use one like it as well.
Great looking set of ribs for the ship.
Yes, please, but I might suggest you post a new log in the tools area with title and have info there for all to see.I actually bought this ''building slip'' about 7 years ago. l believe it is from Billings Boats. lt is adjustable to fit any size hull. lt would be extremely easy to make one though. l could take some photos and give dimensions for the parts if you wish
