HMS Blandford Project Main Support Page
Hi Don,
I just added the material list to my build log.
Mike
Sorry Mike, I can not find the PM for credentials and download, I got the original from notifications not from PMs but it is not there now, do need it as printer made a mistake and I need to get more done,,,,,, ALSO THE BOM DOES NOT HAVE THE DIMENSIONS OF THE RISING WOOD, PLEASE HELP Don
Project Update
The frames are in the checking process and will be available for download this week as Part 2 of the build. We are currently working on the Instruction set and material list additions for Part 2 and they will be available at the same time.
Mike
Since I am building the 1:32, I have a powered jig saw (ryobi) and I guess that I should use something like a 3/8" chisel to knock out the teeth of the jig. The scroll, saw will cut into the tooth, but I am talking about the other part of the tooth that the saw can't get to.
Hi Donnie,
Cut a series of kerfs in the waste, break the strips off with a knife or chisel and use a small file to clean out the corners and finish the notch.
I have that show in my build log.
Mike
Project Update Part 2
All nine frames will be available in Part 2 of the build.
There are two ways to build the frames the first is to cut out all the patterns, glue them to the wood, rough cut and sand the parts to size and assemble the frames.That is the fastest way.
The second way is to treat each frame as a separate project, by starting with one frame and completing it before starting the next frame. You won’t get as bored and will see progress as you go along. The frames quality and your skill level will improve faster using this method.
Mike
Hi Don,
The frames are available for download now and I am posting the construction of frame 1 on my build log.
Mike
Building Jig Top Revision:
When I ran a trial fit on the first frame in the jig it did not seat in the keel, by adding a 30-degree bevel to the center of the top at each notch will eliminate the problem. The angle and depth of the bevel is approximate, no need to check it with a protractor if the frame seats in the keel it is fine. See photos in my build log.
Mike
They are corrected now. Sorry about that. Trying to keep up actually (in code) 36 drawings and making sure all the web code is right is kind of confusing given the long file names to keep things in order.
Go back to page and do a browser REFRESH to make sure the NEW material is there. Otherwise, you will still have the same stuff stuck in your browser cache.
Donnie
Mike needed to re write the instruction set for PART two - the addendum is at bottom of page. Just go to the link for PART 2 and download the instructions.
Thanks for your patience.
Donnie
My PM containing Part One disappeared after the crash last week before I could download it, and this morning I was asked to delete all PM's related to the Blandford. So when someone has time, AND ONLY WHEN THERE IS TIME, could I get both parts sent to me again. Absolutely no rush.
Thanks so Much
Don,
I have been out all evening long. I am just now responding to your request and sent you a PM with Part 1 and Part 2. I apologize for the delay.
Donnie
