I'm trying to follow by notifications, but something is wrong, has a post been removed,
best regards John,
best regards John,
Thanks Donnie. Now I see what you mean. Keep up the great work!@Gennaro
my apologies for not being precise. What I mean is this: I wish that the planking strips bundle supplied with the kit would have been 700mm long. This way, I have the possibility to cut each plank to about 110mm in length and to make sure that I do not have some ODD length leftover (like 25mm or 50mm). If I had the entire length of 700mm to do as I please.
I am cutting each plank to about 110mm which is about the right length in real life. This length ALSO lines up with the center of the frame(s). The planking strips supplied with the kit are only 500mm long. If the kit had provided MORE 500mm length strips, then that is not a problem as I have the extra to cut each one just like I wish for it to be.
This is the post that I am talking about, I was just wondering if it had been deleted, or am I missing something, it would be nice to know,I'm trying to follow by notifications, but something is wrong, has a post been removed,
best regards John,
丁寧な建造。いいですね。Thanks again for all the likes. It is greatly appreciated. Onward with almost closing in Deck #2. The central region will not have planks. I probably should not have spent so much time on the false treenailing as most of that will be covered up by Deck #1, but we will see how it all turns out. At least I know it is all there !!!
The first image is of the Stern view. As soon as this part is done, I must Plank the Hull next (and I am NOT looking forward to that at all). Thank goodness only a portion of the hull is planked.
View attachment 236700View attachment 236701
REVIEW TIME:
Now that I am 6 months into this build, I want to give a short review. Even though this kit is a Plank on Frame (POF) or Plank on Ribs which ever you say it, I want to be clear here. This is NOT an admiralty-style kit. Even though yes there are RIBS and BEAMS, this kit in my opinion does not qualify as an Admiralty style even though from the box art, it does look like such.
I have a few things that disappoint me about this kit. You MUST be careful as some of the parts are STAMPED WRONG and some of the frames are stamped wrong and it easy to get the frames out of order. The plans are only basic and just give you an idea of how things might go together. Next, basically I have given up on the pictorial instructions booklet. I do not see how anyone can build this kit step by step in the progression that they show. The steps are NOT logical in sequence in my opinion.
So, please be aware of these things. I realize that NO kit is perfect, but somehow in the china to English METHODS, there is a lot to be desired.
Just because it is a kit, that DOES NOT mean that EVERY PART has to be laser cut !!!
Hi Donnie,Thanks guys for the 'pep talk'.
Well, I am almost finished with the Gun Ports on one side and I have done a rough sanding to get an idea of how it is going to look. So far, it seems ok. I included some snap shots of the plans. As you can see NOT all of the gunports are made exactly, but have their own unique arrangements. So, the advice is to build one port at a time following the plans.
Kindly
Donald
View attachment 242267View attachment 242268View attachment 242271View attachment 242272View attachment 242273
