Looks very good! I like it.
Witaj UwekMany thanks to all the comments and replys, also for the likes received
Coming back to the windows - it was time to give some glass into the frames
Some time ago my friend Karl Ingwer alias @kalliboot gave me some small sheets of Mika - and I gave them a try - Many thanks once more to send them
fixed the Mika with some small drops of CA-glue from the backside and afterwards the frames fixed in the stern
The frame of these windows are in real very small, so not much space for the glue - but I made it acceptable
Due to the fact, that the windows will be also slightly visible from inside view - once more acceptable in my subjective opinion - hope that the next windows in the next model will be better
The little bit of white wood glue were removed after making the photo (but I have to check if I really did it)
z tej perspektywy możemy zobaczyć odbicie w szkle Mika - zrobiłem swoje pierwsze szklane okna
Wielkie dzięki za zainteresowanie .... Ciąg dalszy nastąpi .....
Mica glass is derived from isinglass, a natural silicate mineral that can be used in older antique toasters (where heating elements are wrapped around the Mika glass), European stoves, coal stoves, furnaces, and even boiler peepholes. It is thin and transparent, having the appearance of cellophane or clear plastic.Please tell me what Mika is, is it some thick foil, film or some transparent plastic. Regards Mirek
Hallo Karl Ingwer,Hallo Uwe,
I missed your birthday, very sorry. Herzlichen Glückwunsch nachträglich!
Glad that you found the Mica sheets i your drawer.
Karl Ingwer
In addition to Jims explanationsPlease tell me what Mika is, is it some thick foil, film or some transparent plastic. Regards Mirek
my dear friendAfter the windows are fitted and fixed I am able to install the planking of the quarterdeck
I will make this planking following in some parts the Lightley model
the deck surface is still not scraped or sanded - caulking is done like everywhere on this model with painting with ecoline
Many Thanks for your interest in my model .... to be continued .....
Good morning Uwek. Bravo. Cheers GrantAfter the windows are fitted and fixed I am able to install the planking of the quarterdeck
Hello, i know this is an old post but I was wondering if you would mind answering a question. So, I understand that once the frames are installed in the jig, there will need to be some fairing done on the outside of the frames, well at least I think so. For POF models, where you see the inside too, do you have to fair the inside of the frames as well?Ja Ja the sanding and cleaning of the frames is taking some time
I have the advantage, that I have a very good spindle sander for the most of the meat, afterwards by hand with a good sanding block. The final sanding will come after all frames are fixed and the complete hull will get the final touch
On these two photos you can see on one side the frames after the spindle sander - and the other after pre-sanding by hand - before a further adjustment will be necessary, especially at the basis where the frames are sitting on the keel
So step by step.........
to be continued ..... and mayn thanks for your interest, all your comments and the likes received
