HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
Uwe, could you explain the process of "treenailing"? It looks very nice and professional. Thanks, Magic Mike
Take a look at this post #625 in which I am showing several working steps of my "actual" treenailing method - I hope everything will be more clear - otherwise I will be happy to answer or show additional photos
I use toothpicks - cut them into two halfs
put the pick on top of a drawplate and give one or two small hit with a hammer
than it is looking like this - o,5mm thick
After marking the lines where the treenailing should be - I press a small mark with a scriber and drill a hole of 0,48mm (smallest Proxxon drill)
In the meantime I am not using any glue - no need
Also single planks are getting treenails - this one is a strip of the inner planking
afterwards I cut the toothpicks with some pliers
and sand or scratch the surface
Many Thanks to @pianoforte , @Herman , @dockattner , @Magic Mike and @Lucian29 for your kind words - much appreciated and a big motivation
also for all the likes recieved - Many Thanks
a small further step is done with the interior planking of the poop deck
the treenailing seems not to end
The final top plank can only be adjusted when I know exactly where the planksheer rail is known ..... the next working step on my list
Many Thanks for your interest .... to be continued ....
That the way it is with treenailing: you know where it starts, but the end....... ;)
It's just beautiful work and it brings the planks alive.
For my possible new build it’s the same with rivets ……… :)
after reading your new log, I can fully understand your words - Puh - this will be some work
but problems are there to be solved....
Peter - especially for you (and a lot of others)
View attachment 391619 View attachment 391621
Uwe, thanks for the detailed explanation of treenails and I also took your advice and checked out post #625 with Maarten. After viewing his workmanship on the "Royal Caroline" and yours on the "Granado" I was already in awe of both you "masters"! Not only are you both gifted but both are very kind to pass along your knowledge to us apprentices. Maarten took the time to give me a detailed report on how and why he does tree-nails the way he did on the Caroline. Thanks to you both (I'm not sure if he is copied on this reply) "Novice" Magic Mike
Many Thanks to @Peter Voogt , @Magic Mike , @Kurt Konrath , @Dean62 , @pianoforte and @Ptèr for your kind words about the latest post and my work on the treenailing
and also to all the likes received
Today only a last photo related to the deck planking of the quarter deck, where I would like to show and compare my planking solution with the model built by Robert A. Lightley
The Original
My Copy
and interesting also the drawing by Goodwin in jis Anatomy book - with straight planking
Everytime I am looking at this original model, I am realizing how much still to do on my model
The next work will be the ....... we will see
Many Thanks to Paul and Tyler for these kind words Redface
The next work will be the sheer rails, so I can finalize the outer and inner planking and the installation of all elements which are in contact with the rails ( like the cathead, anchor lining etc.)
This are the Goodwin drawings showing the vessel from the side
In the kit included are some boxwood strip material, which can be used for the ornamental part of the sheer rails
Unfortunately I did not make a photo of the scratching of teh sheer rail, so for information here a photo showing a strip which is used at the stern, this I made some time ago for testing
The boxwood can be bended like a normal wood - watering and hot iron
This boxwood strip is now installed from the bow up to the stern (sorry no photo) showing the complete length
With the installed boxwood strip I know exactly where at the end the sheer rail is, means also the innerplanking can be adjusted and filled up to this height
I wish you all a nice and relaxing weekend .... many thanks for your interest .... see you soon
View attachment 392401 View attachment 392400
my dear friend
you have done wonderful work on the sheer rails, it's looks beautiful
Very impressive modeling. A lot of lessons can be learned from this build.
And then, daring to compare one's build with a renowned museum piece and surviving, kudos!
Many Thanks for your kind replies and all the likes received
Now I came to the top rail of the sheer rail - herefore some laser cut elements are available in the kit
The first element is the part towards the stern, after sanding down all the tops of the frames etc.
Based by some imperfection of my work, the part is not fitting correctly and has a wider curvature than needed for my hull
based on the original kit part and the real needs, I prepared a correct form in cardboard, which would be my template for cutting out
checking tha cardboard template
With the jigsaw it was not a big deal to cut out from some pear wood (at the end this part will be painted black (I think so in moment)
from outside the sheer rail will have the correct height according Goodwins sketches - from inside only the pear element is visible
Soon I will show the sheer rail preparation at the bow .... many thanks for your interest
