A very, very nice deck Uwe! Congratulations!
			|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
Take a look at this post #625 in which I am showing several working steps of my "actual" treenailing method - I hope everything will be more clear - otherwise I will be happy to answer or show additional photosUwe, could you explain the process of "treenailing"? It looks very nice and professional. Thanks, Magic Mike
That the way it is with treenailing: you know where it starts, but the end.......the treenailing seems not to end
after reading your new log, I can fully understand your words - Puh - this will be some workThat the way it is with treenailing: you know where it starts, but the end.......
It's just beautiful work and it brings the planks alive.
For my possible new build it’s the same with rivets ………
Uwe, thanks for the detailed explanation of treenails and I also took your advice and checked out post #625 with Maarten. After viewing his workmanship on the "Royal Caroline" and yours on the "Granado" I was already in awe of both you "masters"! Not only are you both gifted but both are very kind to pass along your knowledge to us apprentices. Maarten took the time to give me a detailed report on how and why he does tree-nails the way he did on the Caroline. Thanks to you both (I'm not sure if he is copied on this reply) "Novice" Magic MikeTake a look at this post #625 in which I am showing several working steps of my "actual" treenailing method - I hope everything will be more clear - otherwise I will be happy to answer or show additional photos
I use toothpicks - cut them into two halfs
put the pick on top of a drawplate and give one or two small hit with a hammer
View attachment 391619 View attachment 391621
than it is looking like this - o,5mm thick
After marking the lines where the treenailing should be - I press a small mark with a scriber and drill a hole of 0,48mm (smallest Proxxon drill)
In the meantime I am not using any glue - no need
Also single planks are getting treenails - this one is a strip of the inner planking
afterwards I cut the toothpicks with some pliers
and sand or scratch the surface
HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
Sorry my friends for the bigger break and not posting any update of the works. I was on a business trip in sunny Panama, with most of the time not in Panama City, but driving with car direction to Columbian border, with bad or no internet connection, and very small free time definitely the...shipsofscale.com
True storyIt’s not often that someone can compare their model with a famous museum piece and survive the scrutiny. Bravo Uwe! You should be very proud of your work thus far! I can’t wait to see the continuation of this fantastic build.
my dear friendMany Thanks to Paul and Tyler for these kind words
The next work will be the sheer rails, so I can finalize the outer and inner planking and the installation of all elements which are in contact with the rails ( like the cathead, anchor lining etc.)
This are the Goodwin drawings showing the vessel from the side
View attachment 392401 View attachment 392400
In the kit included are some boxwood strip material, which can be used for the ornamental part of the sheer rails
Unfortunately I did not make a photo of the scratching of teh sheer rail, so for information here a photo showing a strip which is used at the stern, this I made some time ago for testing
The boxwood can be bended like a normal wood - watering and hot iron
This boxwood strip is now installed from the bow up to the stern (sorry no photo) showing the complete length
With the installed boxwood strip I know exactly where at the end the sheer rail is, means also the innerplanking can be adjusted and filled up to this height
I wish you all a nice and relaxing weekend .... many thanks for your interest .... see you soon
Very impressive modeling. A lot of lessons can be learned from this build.Many Thanks to Paul and Tyler for these kind words
