HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
Sorry my friends for the bigger break and not posting any update of the works.
I was on a business trip in sunny Panama, with most of the time not in Panama City, but driving with car direction to Columbian border, with bad or no internet connection, and very small free time
definitely the country would need some repair or development of roads and bridges - the last bridge in Panama is only a pedestrian cable bridge - afterwards only jungle
a beautiful country where a civil engineer will find some tasks.....
...... only at the last day I had some hours free and visited the "old" Panama canal
Sorry for not beeing online here in our forum for more than 10 days (also without any birthday wishes etc.)
Good morning Uwek. South and Central America counties have always fascinated me. Riding an off road bike through some parts is on my bucket list for sure. Pity you only had one day to explore. Nice. Cheers Grant
a little progress on the deck planking
first the planks sanded and adjusted to fit between the waterways, hatches and the mortar box
and fixed with the made "Ecoline-caulking"
(according the Goodwin book, the planking goes also over the mast-partners)
Tomorrow the treenailing will follow
Many Thanks for your interest ..... to be continued .....
Witaj
Jak zwykle świetna praca. Pozdrawiam Mirek
Hello
Great job as usual. Regards, Mirek
Many Thanks for the kind reply @Mirek and the likes received. Highly appreciated
Before the weekend, where I hope I can work a little bit more on the model, I would like to show you the latest treenailing works on the deck and the result
Based on a tip I saw in @Maarten building log I adjusted my Tooth-pick treenailing method
with using my drawplate
in order to get a 2 or 3mm long permanent 0,5mm diameter pointed toothpick
a little bit additional work, but let us see the final result, if it is worth to do so
red area - normal toothpicks
green area - with drawplate pointed toothpicks
Now I finished more or less the final planking of the deck - the rest will stay "open" to see the deck structure
and this will be the sight from the other side, which will be visible later on - here also the caulking is slightly visible
Many Thanks for your interest ...... to be continued .....
Witaj
Zielony obszar wygląda super, spróbuj kiedyś kołków z igły lekarskiej wszystkie są idealnie równe i tej samej średnicy. Pozdrawiam Mirek
Hello
The green area looks great, try the doctor's needle pins sometime, they are all perfectly even and the same diameter. Regards, Mirek
A nice result with the treenails, Uwe. Did a few thousand on my BN with the same technique. Very useful and with a constant quality.
Many Thanks to @Mirek , @Tobias , @dockattner , @Kurt Konrath , @Peter Voogt and @AnobiumPunctatum for the direkt comments and kind words and also to everybody for the likes received
Just wanted to show you the comparison between the Goodwin deck plan an my deck planking - The pattern is follwing completely the drawing, so I followed here the Goodwin information for example the locations of joints
(Photo mirrored)
and in addition some closeups to see the "caulking" from the undersight - I could imagine, that in real ships it could also look like this
and the mast partners with wedges are also finally prepared
Many Thanks for your interest - to be continued ......
(Photo mirrored)
wonderful work my dear friend Exclamation-MarkOkay:)
(Photo mirrored)
Looks like a few cross members missing under the planked section.
Great work on this great kit. I agree with Maarten, the underside with all the beams looks very cool!
you have good eyes or recognize such things
The two carlings (red) are on purpose missing and will be installed later on.
They will be installed together with the windlass carrick bitts (green), which will be fixed when I know finally how I will present them - partly cut or completely in the upper half of the model
