HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
Bonjour,
Les avants trous sont de quel diamètre ? 0.5mm ?
Hello,
What diameter are the pilot holes? 0.5mm?
I am using the Proxxon drills nominal 0,5mm - in reality they are 0,46mm
Encore une question, Pouvez vous me donner les co^tes d'encombrement de la boite à construction ?
Merci d'avance
Another question, Can you give me the dimensions of the construction box?
Thanks in advance
In the evening when I am back in workshop I can make the measurement .....
Sorry, but yesterday I came home late, so no chance for a visit in the workshop - Today it will be possible, so the data will come ....
Many Thanks for your continuous interest in my building log
Many Thanks for your comments, hints, remarks and questions
and
Many Thanks for your likes received
much much appreciated and a continuous motivation to follow up postings showing the progress
Not only the boxes for the mortars are necessary to be finished before the deck planking can be finalized,
no also the hatch coamings have to be prepared.
The HMS Granado was an english ship, so the coamings were installed on top of the beams and carlings. Sometimes the french ships were deifferent, here the planking was first installed and the coamings were fixed on top of the planking
The fore hatch coaming is covered with a grating
The grating elements are also lasered - in one direction already with a small camber
a close up to see the extremly good fitting
the coamings were fitted also with copper bolts - on the right the coaming for the main hatch
still missing here are the supports on which the covers are laying
both are more less finished - only the boards will get some eyelets with rings later on
dryfitted on the place
Many Thanks for your interest ..... to be continued ......
Wonderful work on your coaming bolts. Are you using steel or aluminum or some other material? The bolt to wood finish is very nice.
and
Bonjour, la forme bombée est certainement du au bois qui a travaillé.
Comment allez vous redresser cette pièce (peut être en la trempant dans de l'eau et la faire sécher sous un poids ?
Hello, the curved shape is certainly due to the wood that has been worked.
How are you going to straighten this part (perhaps by soaking it in water and drying it under a weight ?
Merci d'avance
Thanks in advance
Now I have the dimensions of the jig
Longueur - length -> 70cm
Largeur - width -> 20cm
Hauteur - Height -> in center 12cm at the endings of the jig 15,5cm
Please have in mind, that for stability reasons (maybe not necessary, but I made it) the hig should / could be fixed to a base board
Hope this is helping
The original curved shape / camber of the carlings was slightly too small, so after finishing the grating I soaked it slightly with water and let it dry fixed around a bigger bottle with some rubberbands. Unfortunately the camber is now slightly too much, so for the final installation I have to reduce the camber once more (in the same way, but I need a bigger radius.
But this step is necessary, only when I show finaly the hatch open and the grating laying next to it - in case the grating is finaly installed on top of the grating, the camber will be reduced by "strong forces" and I use some glue - the grating is still flexibel
Oui j'ai prévu de fixer la boite de construction sur une planche assez épaisse pour rigidifier l'ensemble.C'est la raison pour laquelle j'avais besoin des dimensions d'encombrement. Encore merci pour les renseignements.
Yes, I planned to fix the construction box on a board thick enough to stiffen the assembly. This is the reason why I needed the overall dimensions. Thanks again for the information.
Uwek, what materials did you use for the bolts on your grate coamings? Thank you.
Hallo Ken,
I am using since some time (some models) for metal "bolts" copper nails - these for the coaming have a diameter of 0,6mm (sometimes I use also 0,7mm)
take a look at my post #580 where I show the nails
Ah, yes, thank you Uwek. I guess the reason I asked is I sensed the coaming bolts looked silver to me. I think I will try working with copper bolts to test workability and appearance for my use. You obviously have taught yourself a method that reaches great results. Thank you.
Many Thanks for your interest in my building and all the likes received
I made another small "one day excursion" from the deck planking and prepared the mast wedges, which are fixing the masts against the mast partners.
Also these wedges have an influence on the planking, so therefore once it is necessary
On the left side the additional planking, which has to be installed on top of the normal deck planking (according Goodwins cross section)
and on the right side the cnc milled 8 wedges, here for the main mast
cut our, not sanded or adjusted, only to show the function
let us see, if they fit already into the mast partners?
yes - but now the parts have to be sanded .....
More or less the final appearance
Usually the kit manufacturer are delivering only a wooden ring, and the modeler has to cut the gaps with a knife to immitate the 8 wedges - Here with this kit it is different - Bravo
and the wedges visible from the undersight
Many Thanks for the interest ..... tob continued .....
Sorry my friends for the bigger break and not posting any update of the works.
I was on a business trip in sunny Panama, with most of the time not in Panama City, but driving with car direction to Columbian border, with bad or no internet connection, and very small free time
definitely the country would need some repair or development of roads and bridges - the last bridge in Panama is only a pedestrian cable bridge - afterwards only jungle
a beautiful country where a civil engineer will find some tasks.....
...... only at the last day I had some hours free and visited the "old" Panama canal
Sorry for not beeing online here in our forum for more than 10 days (also without any birthday wishes etc.)
