I am using the Proxxon drills nominal 0,5mm - in reality they are 0,46mmBonjour,
Les avants trous sont de quel diamètre ? 0.5mm ?
Hello,
What diameter are the pilot holes? 0.5mm?
In the evening when I am back in workshop I can make the measurement .....Encore une question, Pouvez vous me donner les co^tes d'encombrement de la boite à construction ?
Merci d'avance
Another question, Can you give me the dimensions of the construction box?
Thanks in advance
Sorry, but yesterday I came home late, so no chance for a visit in the workshop - Today it will be possible, so the data will come ....In the evening when I am back in workshop I can make the measurement .....
Bonjour, la forme bombée est certainement du au bois qui a travaillé.Many Thanks for your continuous interest in my building log
Many Thanks for your comments, hints, remarks and questions
and
Many Thanks for your likes received
much much appreciated and a continuous motivation to follow up postings showing the progress
Not only the boxes for the mortars are necessary to be finished before the deck planking can be finalized,
no also the hatch coamings have to be prepared.
The HMS Granado was an english ship, so the coamings were installed on top of the beams and carlings. Sometimes the french ships were deifferent, here the planking was first installed and the coamings were fixed on top of the planking
The fore hatch coaming is covered with a grating
The grating elements are also lasered - in one direction already with a small camber
a close up to see the extremly good fitting
the coamings were fitted also with copper bolts - on the right the coaming for the main hatch
still missing here are the supports on which the covers are laying
both are more less finished - only the boards will get some eyelets with rings later on
dryfitted on the place
Many Thanks for your interest ..... to be continued ......
Now I have the dimensions of the jigEncore une question, Pouvez vous me donner les co^tes d'encombrement de la boite à construction ?
Merci d'avance
Thanks in advance
Comment allez vous redresser cette pièce (peut être en la trempant dans de l'eau et la faire sécher sous un poids ?
Hello, the curved shape is certainly due to the wood that has been worked.
How are you going to straighten this part (perhaps by soaking it in water and drying it under a weight ?
Oui j'ai prévu de fixer la boite de construction sur une planche assez épaisse pour rigidifier l'ensemble.C'est la raison pour laquelle j'avais besoin des dimensions d'encombrement. Encore merci pour les renseignements.Now I have the dimensions of the jig
Longueur - length -> 70cm
Largeur - width -> 20cm
Hauteur - Height -> in center 12cm at the endings of the jig 15,5cm
Please have in mind, that for stability reasons (maybe not necessary, but I made it) the hig should / could be fixed to a base board
Hope this is helping
Hallo Ken,Uwek, what materials did you use for the bolts on your grate coamings? Thank you.
