Thanks Janos,the rabet is there,I still need to do some sanding,the second layer will be 1 mm thickGreat work, Zoli!
I can't really see it on the pictures. How will the rabbet accommodate the second layer of planking?
Janos
Thank you, Uwe , but there are lots of mistakes, hopefully will be corrected with the second planking.A very good learning exercise for the second planking - we can see, that you already plank like it would be the visible planks![]()
The only way to avoid mistakes, is to stop building models!Thank you, Uwe , but there are lots of mistakes, hopefully will be corrected with the second planking.
Thank you, Lawrence!Hello Zoltan, Very nice work you are doing on your hull planking, it sure does make her all come together, ENJOY.
Regards Lawrence
Thanks Jim,there are much to do before I start the second plankingGreat work , Zoly! Does she is ready for the final layer of planking?
Thanks Dave,I need to sand the hull,than some wood filler and sanding again,I have to order some timbers for the second planking,deck planks and for the upper deck framing.Also There are some works to do on the stern .Good job, Zoly! Anxious to see the second layer!
