regardless the caulking effect,I am worried abut the width of the plank after sandingBesides removing some tens (0.1) of the mm, I like to keep the char on the planks, It gives the natural caulking look representations. However, given the fact that the laser beam 'cut' the material at the angle, I would be very cautious using planks without shaping first. This obviously negates the curved sides, the planks normally require an angle in neighboring planks.
I haven’t tried the hot air gun on wood before. I’ll log that away in the back of my mind.Using a hot air gun to heat and bend ebony can be very simple
A hairdrier will makes it tooI haven’t tried the hot air gun on wood before. I’ll log that away in the back of my mind.
I can relate. My current build presents the same plethora of problems. Just gotta take it slow... Little bites at a time and chew it over thoroughly.It's funny: when you see planking done in the actual manner of the original ship, it looks wrong, uneven and back and forth, instead of long, tapered planks. So even though it is accurate, it is not what we (or at least I) are used to seeing. I'm sure it will be less noticeable after finish is applied. I love the look and size of this model, but don't think I have another full rig build in me.
Good morning. WOW that is stunning planking...Cheers GrantThe planking is almost complete and much to my amazement looks like fitting with no disasters the finish leaves a bit to be desired with lots of glue and uneven surface but hopefully will sand up better
