The next step is the foremast bits.
The bit are build from two cnc carved halves which glued together create a very nice result. Originally the bits are in the kit to high above the deck and as I build the deck contruction I will fit them to the side of the deckbeams and lengthen them to fit also on the main deck.
The sheaves for the bits are from brass which I lightly burnished.
To fit the sheaves I used burnished brass nails for which I cut brass plates to fit on each side of the nail and on these I riveted the end of the nail to close up the nail between the two plates.
The belay pin rack was cnc finished on one side, I finished the other side equally on the milling machine.
The sheaves are fitted and the bit is dryfitted to the deck beam.
Te belay pin rack I fit with counter sunk brass pins to get a ridged construction as these racks will be used.
At the foot of the foremast bit there is a construction to lock up the bowsprit. As my forecastle deck will be partly open I build this construction according the aots book.
For this the bowsprit foot is carved with a square at the correct angle.
Then the construction at the foot of the bits is build, I made this of strips of pear.
Nicely locking the bowsprit in place, before finall fitting the height should be correctly set to give the bowsprit the proper angle.
The bowsprit will be removed again for finall fitting in a much later stadium. You see here that the laser cut hole for the bowsprit is too large, the bowsprit diameter is accrding to the aots drawings correct.
