HMS Royal Caroline kit ZHL 1/30
Dear Maarten,
I was overimpressed with this blog and your passion and creativity. Thank you, it was quite an experience to review it!
As a result, I have just ordered the same kit, so I will have a pleasure of building it with my father (we work together on ships).
I am not sure I am ready to go to the extent you demonstrated but I will definitily use many of you techniques and I think I will decorate the aft rooms, but with much less quality. Because your level is simply unreachable.
As I live in NL, I suggest I will invite you for a drink to tell you "thank you" in person. It is the best ship-building blog I have ever seen.
Dear Maarten,
Hi Alex,
Good to hear you liked it and it inspired you to start the same model. It is a fantastic ship and you won't regret it.
Sounds fun to meet you and I can bring the model to show and discuss, good for new ideas for both of us.
I will send you a PM.
Finally after plenty hour of cutting, grinding and polishing the three figure heads are finished for dry fitting.
First the larger angel figure needed a second arm and a leg extension. I will spare you the bloody details :-).
With this as a result before polishing and waxing.
Finally dry fitting to see if everything fits. The small angel gets a 0.5 mm pin in its foot to fit it.
Then fitting everything in place.
On top of the hands the crown will be fitted.
That was it for 2019.
To all of you many thx for following in 2019, more to come in 2020.
Have a great years end and looking forward to 2020.
Finally the work railing on the ps side is also finished. After steaming them in the right shape I carved out the spaces into the two lower rails to fit the pillars. The pillars are doubled in thickness and will fit snug over the rails.
Now the top of the pillars is sanded to a correct length to make a tight fit with the top rail followed by coloring the rails with black ink.
After the ink is dry the top layer of the wood in the carvings is scraped to remove the ink and a nice contrast appears.
All wood connection I enforced with brass pins and the top rail is fitted with burnished nails to the pillars.
If the glue is dried I can apply some layers of oil to seal and polish it.
Then on to the next step which I think will be the rudder or maybe the poop deck, we'll see.
Dear Maarten
Every once in a very long while - something gets done that simply defies reason or belief. If I had not witnessed this build myself, I would not have believed it possible. You are an inspiration Sir!
Best regards
Heinrich
