Nothing to say other than that looks SO COOL! You have accomplished your mission of building out a proper lower deck. Next up: 100 hours to build the ceiling...(200 hours?)...What do you think, everyone? Can a gun carriage be squeezed in the stern corner or not?
I have nothing intelligent to say about guns; I just make teeth straight...Well, Paul, the next thing it to add the knees, hanging knees, and overhead beams supported by stanchions. Before that, I need to determine whether or not to squeeze these two carriages in the stern corners. Any gun deck experts out there? I need opinions here, guys!
Just from appearance point if view it would look better without it. In my non expert view.Well, Paul, the next thing it to add the knees, hanging knees, and overhead beams supported by stanchions. Before that, I need to determine whether or not to squeeze these two carriages in the stern corners. Any gun deck experts out there? I need opinions here, guys!
Looking fantastic overall. My uneducated opinion it looks a bit tight to have the rear cannon in that position, but as it will be mostly covered up perhaps it's acceptable.What do you think, everyone? Can a gun carriage be squeezed in the stern corner or not?
I would not add the outboard cannons, just the two inboard cannons. Raise those doors and leave the other two closed. That’s my opinion, for what it’s worth.What do you think, everyone? Can a gun carriage be squeezed in the stern corner or not?
I'm going with that plan, Dean. Thanks. And thanks to all of you for helping me past this hang-up so I can get back to building!I would not add the outboard cannons, just the two inboard cannons. Raise those doors and leave the other two closed. That’s my opinion, for what it’s worth.![]()
Pinnace on a Stick. Excellent band name...Thanks guys! This issues has been plaguing me because I am two guns short of what Sephton stated was the number of guns on the lower gun deck. I'll have to live with that, I guess. It's obvious that there is no room to operate that chase gun in the corner. The central chase guns will be installed, but not the outboard ones. Steelf66, when you say the "line for the sloop", are you talking about the painter for towing the ships boat? if so, I should tie a piece of line to some place inside the ship, probably a deck ring, route it through the port side stern port in the corner, and mount the pinnace I made on a stick outside the ship, attached to that tow line. The observer gets to see TWO models, the ship, and the pinnace!
You sorted those cannons out really well. For a non visible installation your dedication for authenticity is applauded. Brilliant.The deck knees were made by routering out a long block of wood in the profile of a typical knee. The shape was sanded and cut into sections to make individual knees. The knees were then stained. The vertical edge of each knee will be sanded to the shape and angle of the bulwark as they are installed one by one. But first the positions of the overhead beams need to be determined and marked, and the beams made and bent to the proper camber. Work on the stern guns was completed and the guns were installed like all the other guns on this deck.
Something had to be done about the silly cone shaped muzzles on the gun barrels provided with the kit. Several gun barrels were placed in a drill chuck and the muzzle cones cut down to a reasonable size using a mill file and a diamond file. The barrels will be painted bronze later in the build.
Assembling breaching line rings, gun tackle rigs, train tackle rings, barrels, and trunnion caps for the two stern chasers.
Stern chasers ready for installation and rigging.
Stern chase guns installed and rigged. Not every spot is detailed on the inner surfaces but those areas won't be visible.
