That’s enough knees for a caterpillar!
You can't threaten the kitty on account of my wife...Hmm. He would make a lovely (albeit expensive) doorstop...
This has been an abysmal year for the loss of talented musicians.Agree with all the above, all about the journey not arriving at the destinationMusic is good for the repetive jobs.Depeche Mode for me for a while after learning of the passing of Andy Fletcher,their keyboard player yesterday
Kind Regards
Nigel
Quick and dirty.Interesting way of making the knees - with a very good result
Of course. You can never have enough. But wait until you see the carlings and ledges! The fun is just beginning. This is what the deck structure for the middle gun deck looked like before it was covered over with deck planking. The upper gun deck structure in progress now will be similar.Are you sure you don’t kneed more knees?
Monnikenwerk, just plain monnikenwerk! Kudos though, it just looks stunning.Of course. You can never have enough. But wait until you see the carlings and ledges! The fun is just beginning. This is what the deck structure for the middle gun deck looked like before it was covered over with deck planking. The upper gun deck structure in progress now will be similar.
Well planned, well executed, and I must say well documented.All the lodging knees were completed on the starboard side today. The process for making and installing the knees is detailed below.
Estimate the angle between the bulwark and the beam where the knee will be installed and chop the piece to that angle.
Knee with the excess material chopped off. The knee should be test fit in the model and the angle, which is just over or just under 90 degrees, should be adjusted to fit.
Miter the corners off the ends.
Roughly shaped knee ready for final sanding.
Round the ends with a sanding block.
Sand the edge which contacts the bulwark to match the vertical angle of the hull at the place where the knee will be installed. This will change depending on the location of the knee.
This edge is angled to match the vertical angle of the bulwark.
Mark the bolt heads with a pencil for added detail.
Test fit the knee to check the fit between the bulwark and the beam. Adjust the angle as necessary. When the angle matches, the knee will be very secure when glued in place.
Finished knee glued in place.
Cut a 3x3mm piece of cherry wood, soak in water, then clamp into the form to bend it to make the camber. This beam will be the last one, closest to the transom.
The last beam on this deck will go here, between the arrows.
New beam placed over an existing beam to check the curvature.
Aftermost beam glued in place.
Cut, shape and sand the last lodging knees, port and starboard.
Test fit the last lodging knee.
Last lodging knee on starboard side glued in place.
Progress so far.
Outstanding!Of course. You can never have enough. But wait until you see the carlings and ledges! The fun is just beginning. This is what the deck structure for the middle gun deck looked like before it was covered over with deck planking. The upper gun deck structure in progress now will be similar.
Yeah Paul. If you look at the top, that's exactly what the thread says.Bashing deagostini beyond believable boundaries.
Yup. That about covers it.
