time for updates,,, I am about half way through first planking, already have made errors,,, (Still a surgeon, confess your errors to the group at M&M)
I messed up the bearding line,, I put the stern post on early by accident following the plan sheets instead of written directions reading into the lines, and ended up sanding the sternpost down with the bearding line,, I don’t think it will be a big deal, I will plank over it and I doubt it will make difference in the end. As I look at the gunport patterns I realize one side is about 3/4 of a MM off and I am upset about that, I was so sure it was perfect as I put it on,, too late now, I will adjust as we go. I also failed to taper the stern extensions a bit before I put the gunport on, so hopefully it isn’t too wide. I can sand things down as I need, And lastly I have already lost a something. I did my inventory and now can’t find a small bag of dome head nails. (Part 696) that I know I had because I was impressed with the quality when I did my first pass through the box. Stupid,,,,
