Imperial yacht Uvalen by Falconet in 1:48 [COMPLETED BUILD]
Before proceeding with the gunwale, deck and so on, I decided to paint the hull, 'cause later it would be more difficult to realize. And before painting it was necessary to make the rudder and its irons. I hate soldering, but in this case it was inevitable :( Yes, it's not a kit for beginners.
Unfortunately, I broke one brace during the process, but I found a substitute for it among the PE parts remained of my old Dagmar kit.
Soldering is no fun but the alternative is CA glue or Epoxy and they are not nearly as strong of a bond on metal.
Can't wait to see her painted!
Soldering is no fun
Sorry for the offtopic @Walterone
Personally, I am not a big fan of soldering, but...soldering can be just as much fun as other processes. Yes, it could be very frustrating and as the result - disliked. But when it works the way you want it, the results are truly rewarding. In soldering, you have to follow strict rules. They are not hard to learn, though, but you have to follow them to achieve the desired goal. Here are some of my recommendations.
  1. Make sure the material in question can be soldered. There are many metals that look exactly like brass\coper, but they are brass\copper plated alloys. It is impossible to solder them.
  2. The surface must be absolutely clean from grease and oxidation. You may use sandpaper first to remove oxidation, then use kitchen vinegar to remove fingertips and other grease accumulated while sanding.
  3. There shouldn't be NO GAPs between soldering parts. Always position parts as tight as possible, without any gap. Melted solder will not go into the gap.
  4. A very important part in soldering playing 'flux', some of them paste while others are liquid. You have to experiment with what works for your given job better. I like a liquid flux, it is not as 'messy' as a paste.
  5. Soldering iron is oftentimes undeservedly omitted from discussions, but choosing the right soldering iron - is half of success. If you soldering tinny parts (like PE), you don't need lots of heat. At the same time, you might need a small and precise soldering point to deliver just enough solder. Contrary, you will need more heat and a bigger soldering tip when soldering 5.0mm rods together.
  6. While soldering, you have to 'play' with melted solder. Once you will learn the 'melted point', you will tackle your job with ease. You will tell the solder where to go! The solder will flow where the hottest temperature is.
Hope this will give you some ideas. These are just some of the points, I am personally using as the primer. Other's will chime in with their suggestions, for sure.
BTW, we have discussed only soft soldering tips, there is a hard soldering process using the torch...but that discussion is for another topic, and time :cool:
I have found that soldering paste makes a huge difference when soldering small parts. I have a tube I ordered years ago and will probably last me the rest of my life. I keep it in the refrigerator when not in use.
I have also decided to paint the hull before installing the rails, but I’m getting as much work done on the decks and furniture as I can before I install the rudder. With all the handling, it is inevitable I will break the rudder before I am done.
That looks great! I have been putting much thought into how I plan to address painting of the hull since I knew, as you pointed out, that masking the clinker hull would be a challenge. Did you brush paint or spray/airbrush?
The deck, the cockpit and the gunwale. I also painted the inner space of the cabin black.
The gunwale is doubled, it means that it has two layers of uniform details, but before glueing them together, you need to round their edges with the profile shaper 0.5 or simply with sandpaper. The result looks something like a sandwich.
