Kingfisher 1770 1:48 POF
Witaj
Pięknie zrobiłeś lawety do armat tyle drobnych części dodałeś wyglądają jak w realu. Pawle czy haki do mocowani lawet były w zestawie czy robiłeś sam ? Pozdrawiam Mirek
Hello Friends,
I'm not sure this is an update (?), or a progress report (?) or what to call this posting... It doesn't really show any new construction - but it does represent the culmination of nearly four months of work since I placed the upper deck. Over the past day or so I have permanently installed everything that sits on the upper deck (except for a few super fragile bits) along with the fore castle deck and the quarter deck.
Check it out:
Next up: the waterways for these decks...
T
Hello Friends,
Check it out:
That looks GREAT, Paul. So much to see!
Hello Friends,
Check it out:
wow. it looks great. Congratulations.
That is a lot accomplished for just 4 months of work.
Hello Friends,
Check it out:
Spectacular, beautiful build Paul. Truly one of the best I have seen.
I really like how you used a partial grating so there is a bit of a view below. Making proper full gratings is hard enough, then to make a well done partial grating is wonderful to see.
Beautiful work Paul. Looking at the top picture port side open rib view it dawned on me by using such light-colored wood, any bright overhead light will light up the interior down to the keelson which one could view I believe quite well. And by the way, when you install those super fragile pieces it will be quite supercalifragilisticexpialidocious!
Paul,
From your Vasa to this - YIKES , not just better - but a jump in "light speed"!!!! - my simile (comparison?) is questionable :) but you get it - awesome work
Good afternoon, Paul! Could you tell me when the kitchen stove was moved to the upper deck on the Kingfisher?
I'll explain my interest. The fact is that in the archival drawings of Swan and Kingfisher, the kitchen stoves are in the hold. In Marshall's painting there is no stove on the upper deck either. Your oven is at the top. Removing a brick stove from the hold and installing a metal stove on the upper deck is a complex job that requires major modifications to the hull. Maybe you have information on this issue?
