Hello Friends,
Thanks for all the
likes from my last posting! The headworks were brought to a conclusion this week (well, the figurehead remains to be attempted, but most everything else is done).
First up here is a 'seat of ease' (you can sort of see the discharge tube/box on the underside of the grating):
Next, I fabricated something called a boomkin. A boomkin is part of the system that controls the lower corner of the fore course (the lower square sail on the foremast).
I used some leftover boxwood to begin the fabrication:
And then a knife and a plane to do some preliminary shaping:
Finally, I hand sanded the #$%^& out of it until it was as round and smooth as I could get it:
In the images above you can see the boomkin capsquare in place (just a supersized version of what you would find on a gun carriage). Here's a closer look:
Next up was a rather decorative block call a cat block. The cat block is a snatch block that sits on the cap rail (and, curiously, over/around one of the timberheads). Its fabrication is made somewhat more complicated by the fact that it curves to follow the turn of the rail):
First attempt:
Success:
Finally, I added the berthing rail which acts as a framework for some safety netting. I don't think I'll add the net itself, but I did want to include the rail on my model:
This is just round brass stock
blackened with Casey's. I was somewhat surprised to see that the Casey's even blackened the solder joint I used to close the loop:
You have to love a product that works.
My attention will now turn to the waist area of the ship where I left some loose ends.
