Paul, have a nice family time and rememberance, and the aft section of your Kingfisher looks awsome
Paul, what and how are you sanding the inside of the frames? I will be at this stage soon...thanks
Hi Paul. I am enjoying following your build.Paul, what and how are you sanding the inside of the frames? I will be at this stage soon...thanks
Wow, 80 grit is so coarse and using a power source to apply it. Boxwood must make pear wood seem like balsa wood. Just curious Paul, are all the other ships members like planking, mast, railings etc. made of boxwood?I am literally spending hours with a sanding wheel and 80 grit.
Oh my, no! Not 80 grit in a power sander! I'm using a small sanding drum in a Dremel knockoff:Wow, 80 grit is so coarse and using a power source to apply it. Boxwood must make pear wood seem like balsa wood. Just curious Paul, are all the other ships members like planking, mast, railings etc. made of boxwood?
Hello Paul @dockattner first of all thank you for your compliment, @Paul132 now for sanding the inside of the frames, I prepare each frame slightly and that depends entirely on the area where the frame is. The frames in the stern and bow area are lightly sanded with 240 grit, in the middle sector they are only scratched. When everything is built and glued together, all you have to do is scratch. The exterior is roughly pre-sanded with a Delta grinder with 120 and then 240 grit, then scratched again and finally polished with 000 stainless steel wool. I hope I could help.Hi Paul. I am enjoying following your build.
I wish I could be inspirational or edifying here, but I am only using sandpaper. Well, that's not precisely accurate...I'm using a rotary tool (Dremel knock-off with a sanding wheel) for bulk removal and then 80 grit sandpaper on a small curved sanding block for rough shaping. I force myself to get the most out of this stage and then use 120 grit with the same sanding blocks to further refine the shape. It is easy to want to advance to finer grades of sandpaper but when I do that, I invariably return to coarser paper so I am learning to get the most I can out of the coarse papers. I am literally spending hours with a sanding wheel and 80 grit.
@Tobias has been using scrapers and getting GREAT results but I am uncertain when he moves from bulk removal to scrapers - perhaps he can advise....
Looking at a guys aft sections sounds a little personnel there! Ha Ha...Paul, have a nice family time and rememberance, and your aft section looks awsome
Hello Kurt, I mainly buy from DICTUM, see the link. You can also get scrapers from Amazon, e.g. from the company Kirsch.Tobias, looks like you have a great scraper collection, where did you buy them from?
Nicely done!Hello Paul @dockattner first of all thank you for your compliment, @Paul132 now for sanding the inside of the frames, I prepare each frame slightly and that depends entirely on the area where the frame is. The frames in the stern and bow area are lightly sanded with 240 grit, in the middle sector they are only scratched. When everything is built and glued together, all you have to do is scratch. The exterior is roughly pre-sanded with a Delta grinder with 120 and then 240 grit, then scratched again and finally polished with 000 stainless steel wool. I hope I could help.
Thank you for sharing your approach, @Tobias. Noteworthy is the precision of your original frame fabrication. You are clearly cutting to a fairly precise tolerance (I suspect 1 mm or less) so there is very little excess to be removed. Also, the frame pairs are joined which makes matching them up more 'controlled' (once you figure out which lines to follow on the patterns).Hello Paul @dockattner first of all thank you for your compliment, @Paul132 now for sanding the inside of the frames, I prepare each frame slightly and that depends entirely on the area where the frame is. The frames in the stern and bow area are lightly sanded with 240 grit, in the middle sector they are only scratched. When everything is built and glued together, all you have to do is scratch. The exterior is roughly pre-sanded with a Delta grinder with 120 and then 240 grit, then scratched again and finally polished with 000 stainless steel wool. I hope I could help.
Entirely correct, so i changed it a bitLooking at a guys aft sections sounds a little personnel there! Ha Ha...![]()
Tobias, when you say scratching the mid timbers, do you mean scraping with the scraper blades? Thanks!Hello Paul @dockattner first of all thank you for your compliment, @Paul132 now for sanding the inside of the frames, I prepare each frame slightly and that depends entirely on the area where the frame is. The frames in the stern and bow area are lightly sanded with 240 grit, in the middle sector they are only scratched. When everything is built and glued together, all you have to do is scratch. The exterior is roughly pre-sanded with a Delta grinder with 120 and then 240 grit, then scratched again and finally polished with 000 stainless steel wool. I hope I could help.
That's almost certainly correct Paul. Tobias is likely typing/writing in German and using a translator so sometimes it comes out a little funny.Tobias, when you say scratching the mid timbers, do you mean scraping with the scraper blades? Thanks!
