The following are a series of images that show my progress planking below the main wale (only one side of the ship will be planked - both inside and out). The wood species is American Holly. It is a joy to work with compared to the boxwood. It can be bent and shaped using heat only (avoiding the use of water speeds things up because I don't need to wait overnight for soaked or steamed wood strips to dry).
For heat I am using one of those plank benders based on a soldering iron for acute bends, as well as a heat gun (the kind used to remove paint) for more ordinary bends.
There are six rows of top/butt pattern planks and then straight planks below that.
I had to start somewhere...
I am using a tapering gauge on a mini table saw for these cuts. I think it is silly dangerous, but reproducibility was important for these pieces.
Two rows in place:
At the stern:
And at the bow:
A closer look at the top/butt planks:
Despite the workability of the wood - I continue to use sheet stock for many of these planks. In the image below you can see the cardstock template and a tracing of that template onto a sheet of 1.5 mm holly. An interesting shape!
More progress...
For the pieces that don't need to be cut on the table saw I am just using a miniature planer. Here is my setup: one slot for 1.5 mm stock and a second slot for 2.0 mm stock...
That's about it for now. I do appreciate that you take the time to visit!
