Pity, as I have been waiting to see the nailing of the stern planks. Do you know if this would be a mix of metal and treenails, pure metal or . . . ?Many Thanks for the interest - I promise, it will be (for the time) the last Planking and nailing post![]()
Hallo Poul,Pity, as I have been waiting to see the nailing of the stern planks. Do you know if this would be a mix of metal and treenails, pure metal or . . . ?
Again, no expert...I am still thinking about how I show the fastenings at the stern, but definitely no treenails
Just one comment about the photo shown.Yes, I meant the area you marked with red (but maybe also the area I have marked with violet although I'm aware that most of the nails in this area will be hidden by decorations).
Most of it I think is more or less obvious but would there be nails in each of the 9 vertical timber in the area I have marked with a black square?
You are right that this would not be so massive in real - I guess it is a reason of stability (of the fragile kit parts) and to make it easier for the modeler.The helm port framing is peculiar with 9 timbers to form a really massive solid piece extended that high in the center of the stern. In reality, I would think that these timbers should only be extended up to the lower transom: basically in line with the top of the red lines. But never mind, that seems to be the way the stern is framed in the kit.
I will take this into account and will make the nailing after opening the helm port - rudder coat is another challenge - I have planned it and the kit contents also some very fine canvas for this.....Do not forget to cut the helm port before nailing. Right now you do not have an opening for the rudder to go through. Then, you can take care of the nails.
As for the nails into that solid piece (those 9 timbers in the center): I would only nail the planks to the center and the side timbers. That will give you about the right spacing along with the other vertical timbers. Nails should be installed around opening of the helm port as well unless you plan to install a rudder coat later.
You are correct - I forgot once more the helmport openingWell, looking at Boudriot's drawing, Giles' words as well as my own aesthetic perception I think I'll rather make the lower middle section something like the blue dots (around the helm port the nails through the leather)
Very good, that you are reminding us on the report in Frölichs book "The Art of Shipmodeling" "L'ART DU MODELISME" "Die Kunst des Modellbaus"Here's is an alternative nailing pattern from Bernard Frohlich. Of course, this is less accurate as he was not working from a PoF model. It sure is purty though.
If you want to follow Boudriots information you have theoretically there a vertical structural element, than you have to make a nailAh but there are no frames running through our false windows, so nails in them would not make much sense.
