Your way of working, Uwe is fully convincing, logically thought out, consistenly executed, clean presentation in manageable steps. Ein Spitzenmann halt.
I fully agree with you @pianoforte. This is the place to learn and marvel.Your way of working, Uwe is fully convincing, logically thought out, consistenly executed, clean presentation in manageable steps. Ein Spitzenmann halt.
Hello Uwe.......... noticing the dark edge of your deck planks......may I ask again what you used for that ?Many Thanks for your comments and likes
After installing the inner planking of the rails I was able to reduce the height of the frames to the correct height and adjust the top timber of the rail
Thre lengths of the top timbers have to be still adjusted (after final fixing - in moment they are dry fitted only)
The view from inside
Very good visible are here the top of the frames passing through notches in the top timber - these are the basis for the oars
The small gap between the lowest inner plank at the keel will be later on not visible any more (I shortened the plank just 1mm too short)
and the view of the situation aft
These are photos of the status some days ago....... since 4 days I have electricty problems in my workshop, due to the fact, that the main fuse is defect.
So I have to wait for a sparepart - a mandatory break not able to work on the model ....... sh.....
It is a good question, Oliver. I am wondering if the Ecoline doesn't 'bleed' all over the place as it penetrates the wood.What is the benfit ot the difference to normal acrylic colors. Any experience with lightfastness ?
I used the tip made once by @Maarten on his model, so I used these coloures here the first time.@Uwek
What is the benfit or the difference to normal acrylic colors. Any experience with lightfastness ?
It is really a s... situation.With of without electricity, you‘re doing so well.
