Ok yes thanks. I’m still trying to figure out how to get the cuts where the joints should be. It’s reallyGood morning Tony,
Very nice to see you eagerly at work. First of all, get well soon.
Note that the first foot boards of the first and last frames are subdivided, but only one half of the frame.
And the other half is separated in the middle
Here is an example from La Palme
View attachment 344354View attachment 344355
Yes just some balsa blanks to visualize what I’m trying to do. Me too. I think this method is a time saver. If it’s as accurate as far as joint position goes remains to be seen.you are making already some saw-dust - Bravo
Good point by Tobias (I have to state, that I never did this way of framing by Hahn. So I am very interested in the comparison of Pros- and Cons of the different methods -> It will be great to see here in this group build both variants....... This is so cooool![]()
Hi Tony,Ok yes thanks. I’m still trying to figure out how to get the cuts where the joints should be. It’s really
not possible because every frame is different.
Yes I was that line that splits the frame at the bottom. In order to have the joints match the plans perfectly each and every frame blank will be different. That’s not the point of the Hahn method. The point of to make it easier to cut frames out of one or two sizes of blank. How do you get your joints where they need to be ?
Ok yes correct. Same principle really. Ill be using a combination of methods like this.Here is another example of how @Olivers Historic Shipyard did it.
I think it is also a good method.
As far as I remember, from a conversation with Oliver, he takes the copies, glues them on, cuts it out generously and then glues on a whole frame copy again to correct minor deviations
Thats what I want to know. I thought they had to be to be accurate ?? My hull will not be planked so I’d think it’s going to be very visible if the joints are at random. ??? Yes ? No ?
Yes this is something I don’t know. I did lay out my blanks so the joints are no doubt in the ball park anyway, both floor frames and half floor frames.the joint line is very fine and i do not think anyone will take notice of where the joints are and i do not think it matters. f
Hi Tony, the carpentry I have you do according to certain rules or otherwise you just make compromises, in my opinion, FrankQuesto è quello che voglio sapere. Ho pensato che dovevano essere precisi ?? Il mio scafo non sarà fasciato, quindi penso che sarà molto visibile se le giunture sono casuali. ??? Sì ? No ?
Yes Ill see how the first few frames look.Hi Tony, the carpentry I have you do according to certain rules or otherwise you just make compromises, in my opinion, Frank
if you allow me, there is more study than manual skill in this type of construction, the more questions the betterYes Ill see how the first few frames look.
First and foremost, each builder should decide for himself how he builds and, above all, in what style he builds and what requirements he has. Of course, you can also cut out the frames as a whole to avoid the whole procedure, but you can also pay a lot of attention to originality and this also includes the joints and a certain symmetry. Especially if you don't plank, you can see the joints very clearly, because you can see a colour difference through the different wood grain and other boards.Yes this is something I don’t know. I did lay out my blanks so the joints are no doubt in the ball park anyway, both floor frames and half floor frames.
the joint line is very fine and i do not think anyone will take notice of where the joints are and i do not think it matters. if you were framing a hull lke this you would have to be very accurate with over lapping to create a smmothe sweeping belt of timber.
View attachment 344411View attachment 344412
