Le Saint Philippe 1693 after Jean-Claude Lemineur (Ancre) in scale 1:48
The rough-in of the gunports (and lights) is now complete:
Inexplicably I made all six of the first deck gunports too wide. In trying to reconstruct how that happened it seems that the initial measurement was wrong as every port is too wide by an identical amount. It is also true that the monograph specifies one width, and the drawings show a different width. Unfortunately, I must not have caught that difference during the research stage.
In any case my solution was to insert a thin fillet - the planking will make this repair largely disappear.
A first deck gun port:
A second deck gun port:
Next up are the upper and lower sills.
Thanks for stopping by!
Looks really good Paul - perfect alignment. Have you decided how much you're going to plank yet ?
Paul,
I was looking through you log and got curious about the ship - Found this - You've probably already
gone through this but in case not....
Paul,
Thanks, John. Much appreciated.
Well, that was a lot more work than I anticipated...
Looking good. Can't wait to see the sills.
BTW if you get serious with this type of construction you may want to upgrade your mill to make your life easier than with the Proxxon. I picked up my TAIG for under 900. They had many of the manual mills in stock reconditioned for trade ins by those exchanging them for CNC models. I chose TAIG per Jim Byrnes reco. It has a longer bed and is already equipped with the stepper motor to turn at 10000 RPM needed for hardwoods. You have to by that add on with Sherline. I do use many of the Sherline accessories though.
Hi Chris (@CLB), where did you find your TAIG mill? Locally? Which model would you recommend?
Logging my first post to say how enjoyable it is following all your build logs dockattner, this new build looks like an absolute pearler!
Reading through the comments mentioning the differences between the main Ancre authors, is there any chance that the difficulties people encounter using the author under discussion arise from the paucity of 17th source material relative to later periods? Or is it more from say the differences between the monograph's drawings and body text (i.e. the gunport example you mentioned)?
Look forward to following this log with great interest!
Welcome to the forums !
