Le Saint Philippe 1693 after Jean-Claude Lemineur (Ancre) in scale 1:48
Wonderful craftsmanship. A real eye opener!
I have a question Paul - If you decide to use sanding dust and glue to mask gaps, how do you prevent the mixture being a much darker and more saturated version of the wood colour? I have always found this a problem and never found a solution.
Instead of glue, experiment with mixing sawdust with cooked white rice as a filler. The rice dries rock hard and will take stain the same as wood.
A very skilled approach, and awesome results, mon ami!
Thanks, Jim. This step turned out better in my imagination - but it's mine and I like it.
Beautiful work Paul, I really like the curved upper frame of the lights (or are those also canon ports)?
Curved upper: just following the plans - though I agree it does add some visual interest (I think these are still gun ports, but...).
You are too hard on yourself Paul. Your work has always been a progression of very skillful modelling that many of us can only wish to attain. As I look at your photos today I can only mutter to myself “I wish I could do as well”. Truly great work my friend.
What @RogerD said! Great results!
Thanks, guys. Yes, hard on myself is what I do best ROTF. I've seen these sills done better - but also 'not better.' I did the best I could, so as I mentioned to Jim above I have really no option but to like it.
Hi Richard. Your experience is why I'm not a huge fan of this approach.
And suddenly, from the other side of the world, a possible remedy! I am fascinated by this idea, Namabiiru, and I'm confident others are as well!
Very interesting. Does the type of rice matter?, long grain - short grain. What about the long term implications, degradation, insects?
Sticky rice, not minute rice. Japanese craftsmen have been using rise as both an adhesive and a filler (rarely needed in Japanese joinery) for centuries so insects and degradation are not known to be problems.
We have used it in our book restoration business for years. We add a few drops of clove oil which stops it going mouldy, but once it is properly dry it lasts for many years so long as the insects don't find it..
Hello Friends,
Today I wrapped up the gunport and window (light) upper and lower sills.
Under macro imaging the joinery is mediocre at best, but keep in mind that the entire outer surface of the hull will be planked. Since the inner surface of the hull will not be planked I tried to get those joints more closed - but at this stage in my development as a modeler this was the best I could do (I need to figure out a way to standardize the cutouts in the framing).
I'm not a huge fan of using sawdust/sanding dust to fill gaps but if my eye keeps being drawn to certain gaps, I may have to resort to that.
I believe this leaves the 'skin' of the ship mission accomplie. Time to do some trials and figure out how best to 'finish' the pearwood before starting to add things that will make sealing and protecting what you see here impossible.
As always, I am grateful that you would take time away from your own models to see what I have been doing.
So, I went looking for your gaps that needed filling and, well, I wouldn't. They would probably fill with paint or something, but would never detract from your precise work.
Gaps aren't REAL gaps unless the light gets through (like when the wing on a plane flexes and light shines in near your feet! It happened to me once as a passenger in a DC3 flying from Port Moresby to Kokoda. I was very quick to call THAT a gap and the pilot returned us safely to Port Moresby).
Love your work, Paul.
Hello Friends,
Paul - the joints look fine. Believe me I get obsessed with small gaps and imperfections. These are glaring to you right now but will fade from memory once you move on with your build. As you've said you are planking anyway - nice work on a difficult frame.
Thank you for the encouraging post, Ian!
Thanks, Chris. Of course you are right, but it is my habit to present my work in macro, so the camera and lighting never fail to highlight the imperfections...
Hi Paul,
Indeed mediocre, from you we don't expect anything else than perfect. And now you show us this. You are letting us down.
Serious? You are ruining this hobby for us. We don't dare to share our results anymore. Pff Mediocre.
This Paul, we call that exquisite work.
Then at least we can call our own work mediocre instead of just plain awful.
ROTF ROTF ROTF
