Le Saint Philippe 1693 after Jean-Claude Lemineur (Ancre) in scale 1:48
With all that said, it is enormously satisfying to look at the above images and know that I started with a few pieces of one-inch-thick lumber :) leaning against my work bench about two months ago.
I’m with you on this, mon ami. I’m fully satisfied with all the images you’ve shared. It looks like you’re on the right track and clearly know what you’re doing.
may be on the right track, but I'm not sure if I'm driving the train or the train is bearing down on me
Well..., either way, mon ami, you are definitely on the tracks, so that is a good start. If you are driving the train, full steam ahead. And if it is bearing down on you... Just hold up a hull and hope it stops to admire your craftsmanship. ;)
Hello friends!
This weekend was spent getting the frames to fit the keel and the jig.
On my Kingfisher build that all just happened without fanfare as a product of the excellent kit design. In the case of this scratch build it required far more fiddling. I ended up needing to remake one (double) frame, and there are a few others I'll be keeping my eye on when the fairing of the hull begins. I also needed to re-do a few of the frame floors - in this case it was more of a patch job than a do-over. If you know where to look the patches are temporarily visible but this will all be covered by planking so eventually no one will know. I'm learning as I go...
As I was fitting each frame in turn, I also removed the paper templates, rubbed off the rubber cement residue, and did some light sanding on the fore and aft faces of the frames. All in all, a surprising amount of work to get to the point that I could take a few pictures:
Obviously, everything is just sitting there loose.
I had the most marvelous epiphany this weekend: a scratch build does not come with instructions ROTF. There are a number of things I COULD do next, but no one to tell me what I SHOULD do next. Clearly, certain things need to happen before anything is glued and before frames can be faired - but my lack of experience is not easily ignored.
Thanks for stopping by!
Perfect. The subframe is worth its weight in gold, and your ribs look great.
Wonderful work, Doc. Your postings are quite inspiring! I hope you don’t mind if I pull over a chair and watch the proceedings from your lawn.
You are most welcome, Oliver. The box of cigars is inside the door to the left...and the wine cellar doors are unlocked now that my children have moved to their own places :).
Hello friends!
There is no more satisfying build then a scratch build.
In particular when reading the drawings goes well and the result is correspondingly. Where you are satisfied in the first instance. And re-do’s are part of the job.
Given what you show now, this all works out for you, Paul. My respect!
Thanks, Peter. So far so good. Waiting for the other shoe to drop (an American idiom that means: waiting for the inevitable to happen).
You forgot one for me important step: to make your own design on basic of the historical sources.
Good afternoon Paul. I am a bit late to the party however with only 5 pages in, a spectacular party it is.
I’m a great admirer of the Dockattner ship building experience so I am looking forward to this scratch build instalment and have pulled up my bed(I can’t sit much yetROTF)
It has been so good to catch up with your new project and I’m starting of with a WOW.
Cheers Grant
Cheers Grant
Yup. I'm hiding over here on the quieter side of the forum. In an interview I heard Olha say that she tried to begin her YouTube campaign with scratch builds and similar projects, but things didn't take off until she started showing how she was building kits. Apparently, when she asks what people want to see next, they all ask for more guidance on kit building.
Anyway, the smaller audience on this side of the forum will be very nice. I appreciate the interaction with other modelers and perhaps this project will allow that to happen in a more docile way.
So far no one has complained about your incline bed being in the way...but your wife IS annoyed by the bell you ring when you need something...
Hi Paul
I'm a bit late to the party. Do you have any spare chairs?
Well congratulations my friend you've choose a top tier model to build and I have no doubt it will be a masterpiece.
It was a little surprise to me as I thought you were leaning toward La Renommée but it's even more awesome project.
You want to keep it under 200 pages..... I have a mixed feeling about thisROTF
Hi Marc, FYI - your SR model is why I didn't take these plans and try to build a Soleil Royal (which has an even more ornate stern section). The experts would have been all over me ROTF.
Berain's SR doesn't have that much complicated ornaments. I would say the it's a little more difficult, besides those experts aren't that annoying there're more irritating advisers out in the wildROTF
