Regular liquid cyanoacrylate. There are many manufacturers.I'm not complaining, I was just curious. Lighting always plays some tricks and the difference between threads is very subtle
What glue do you use to connect the threads?
I use a soldering iron, power 75 W, but sometimes silver paste if the load is heavyHi, Alex, when you solder as on pictures below, do you use a solder iron or a silver soldering with a torch? If you use an iron what is the wattage?
View attachment 454976 View attachment 454977
True storyBut it looks beautiful
Kurt, thank you. I really try. For me, this project is primarily to test my capabilities, what I am capable of. So the bar keeps getting higher and higher.Alexander, your model of Victory stands out as one of the best I've ever seen. The details of the rivets were so precise that it appeared to be a real full scale rudder! Your model is becoming a masterpiece.
I noticed that in my builds too. You start out with a certain level of detail and work in mind, then end up totally changing everything, all for the better. In the end, the model looks totally different that you thought it would at the beginning.Kurt, thank you. I really try. For me, this project is primarily to test my capabilities, what I am capable of. So the bar keeps getting higher and higher.
Grot-under-lisel-spirits = Main lower studdingsail booms. What miracles does google translate sometimes workInstalled grot-under-lisel-spirits.
I laugh sometimes myselfGrot-under-lisel-spirits = Main lower studdingsail booms. What miracles does google translate sometimes work![]()
