MY BLUENOSE- YUANQING SCALE 1:72 SCALE [COMPLETED BUILD]
I can't find the mast hoops in the Instruction book. How many do I make for each top mast?
I'm making extras and selecting those that come out the best. I had 12 extras on the lowers.
This has turned out to be one of the more enjoyable parts of my build.
Happy modeling
Ted
Hello Ted, I believe that I had 9 hoops for each mast, you may need an extra one or two depending just how you space them, Have fun.
Regards Lawrence
Made a bunch of the hoops as most were raggedy.
Once again using .5mm thick shavings made this process easier and improved the finished hoop dramatically.
The results are so improved that I would scrap the original set made for the lower masts had I not run out of scrap wood from my Swift project.
Best regards
Is it best to glue the masts to the hull or rely on the rigging to keep them in place?
Happy modeling
Ted
Hello Ted, I never glue in the mast to the hull, it is nice to be able to align and rotate the mast. Your shrouds will keep it in place once you lace up your dead eyes, hope this helps.
Regards Lawrence
