Canoe21
Lawrence
Hello Johan, Yes that is true in most cases, besides she has much better tast for colors than I do.What the Admiral wants, the Admiral gets...
Regards Lawrence
**VIEW THREAD HERE** |
Hello Johan, Thanks for your very kind words, Yes the aft deck planking went quite well after our re-doo start.Nice job with the decks Lawrence, another sub-project closed successfully.
Exactly, that's how we, males, convince ourselves.Hello Johan, Yes that is true in most cases, besides she has much better tast for colors than I do.
Regards Lawrence
Good morning Lawrence. True storyWhat the Admiral wants, the Admiral gets...
Good morning. Excellent work. I do agree with your Admiral re the tung oil as the deck finish. Cheers GrantHello Ship Mates, The little fellows and I have completed installing the stern deck planking. My Admiral said that she is starting to look like a real ship now, We took that as a plus.
Regards Lawrence
Hi Lawrence. You may not be surprised if you hear from me: 'Oil'. Because that's what I came up with on my deck.Hello Ship Mates, This afternoon we made up 3 color test strips for the deck finish that will be coming soon. We tested Tung Oil, Minwax Putitan Pine # 218 and also Minwax Provinincal # 211. We gave each test strip a coat of Minwax Polyurethane Clear Semi Gloss and my Admiral chose the Tung Oil for the deck finish.
Regards Lawrence
Hello Johan, This is very true, but she dose have a better feel for colors than I do.Exactly, that's how we, males, convince ourselves.![]()
Hello Grant Yes I do believe that my Admiral has made a a fine choice. Thanks for your vote.Good morning. Excellent work. I do agree with your Admiral re the tung oil as the deck finish. Cheers Grant
Hello Peter, Yes I do remember that your color test. The Tung Oil dose seam to have a much deeper softer color.Hi Lawrence. You may not be surprised if you hear from me: 'Oil'. Because that's what I came up with on my deck.
Good morning Lawrence. My wood experience is limited so an elementary question if I may. I’m thinking of using Tung oil on my Cazador deck as well. Do the deck fittings still glue sufficiently to an oiled deck or does one have to use a different glue base?Hello Grant Yes I do believe that my Admiral has made a a fine choice. Thanks for your vote.
Regards Lawrence
How nice that a saw has been used in a different creative way.Hello Ship Mates, Well today the little fellows and I finally got up the nerve to add our long planed idea to add 12 cut outs to the unfinished starboard side of our YQ-Bluenose. These cut outs are rather small at .980" x .484" or 24.90 x 12.32 mm . We would have liked to go a little deeper but the lower decks fore and aft put a damper on this idea. We also completed the transom, painted the inside and cleaned up the outer starboard hull planking .
Regards Lawrence
Hi Grant. Although your question has been directed to Lawrence, I hope he will allow me to share my experience here.Good morning Lawrence. My wood experience is limited so an elementary question if I may. I’m thinking of using Tung oil on my Cazador deck as well. Do the deck fittings still glue sufficiently to an oiled deck or does one have to use a different glue base?
Cheers Grant
I'll weigh in too, Grant (sorry Lawrence). At one point in my Vasa build I proudly presented my newly oiled hull (boiled linseed oil) to the forum and there was a collective GASP. You didn't apply oil already, did you? Nothing will ever stick to the hull... That sent me digging deep into the mysteries of wood finishing and I arrived at the same place Peter did experientially. While it was true that attempts to glue things to the hull early on created very weak bonds - after a while, things got much better. Now, with all that said, my research also indicated that tung oil is a different beast. It never really 'dries in' and bond strength will forever be compromised (though I believe Heinrich uses tung oil and he might have some helpful tips here). In any case: caution. If I had it to so over again I'd be slow to treat with oil until most everything is glued in place.Hi Grant. Although your question has been directed to Lawrence, I hope he will allow me to share my experience here.
I provided the deck of my BN with (boiled linseed) oil in early May 2022 —> Page 98, post #1960 <—. Then I built up the deck. The oil has to be 'dried in' quite a bit before an acceptable adhesion can be obtained. And everything is still in place and has already survived several transport activities. I mainly used CA for the bond. I have always slightly roughened the surface or edge to be glued. Oil and glue are not friends, but the adhesion is acceptable. Now after about a year the oil has dried more on the surface and the adhesion is getting better. I still need to add items.
But ….. the best is glueing before oiling.
But ….. the best polishing of the oiled deck is made with nice long strokes over a flat deck.
I just don't know what the different drying properties are between Tung oil and Linseed oil.
Hello Grant, Tung Oil is a funny beast to say the least. Once applied to your wood or deck or what ever it dose not like to accept glue of any type. This is the reason for me holding off on oiling my ship, even with the temptation is so great to see just how nice it will look after it is applied.Good morning Lawrence. My wood experience is limited so an elementary question if I may. I’m thinking of using Tung oil on my Cazador deck as well. Do the deck fittings still glue sufficiently to an oiled deck or does one have to use a different glue base?
Cheers Grant
Hello Peter, I thank you very much for your kind words and overly nice comments. Thanks for your understanding on just why I had to put a saw to my YQ-Bluenose. I wanted to show how the seamen lived and worked on these little fishing schooners for months on end at times. My Great Grand Father commanded one of these fishing schooners in the early 1900"s as did his father before him. So as you can see it has a special meaning for me to do so.How nice that a saw has been used in a different creative way.With a result that looks promising. Respect for this ‘drastic’ step, Lawrence. Because once you start there is no going back. And the cutouts of every 2 frames give a nice regular pattern.
Hello Peter, no problem at all for posting. Very good advice, I just love that Tung Oil look but it dose have it's drawbacks that I have found over the years.Hi Grant. Although your question has been directed to Lawrence, I hope he will allow me to share my experience here.
Hello Paul, No apology necessary. You also give very good advice and that is why I love the SOS Form, it helps other ship builders to avoin some of our mistakes. Yes Tung Oil dose do a very nice job but it can also give a great deal of head aches.I'll weigh in too, Grant (sorry Lawrence). At one point in my Vasa build I proudly presented my newly oiled hull (boiled linseed oil) to the forum and there was a collective GASP. You didn't apply oil already, did you? Nothing will ever stick to the hull... That sent me digging deep into the mysteries of wood finishing and I arrived at the same place Peter did experientially. While it was true that attempts to glue things to the hull early on created very weak bonds - after a while, things got much better. Now, with all that said, my research also indicated that tung oil is a different beast. It never really 'dries in' and bond strength will forever be compromised (though I believe Heinrich uses tung oil and he might have some helpful tips here). In any case: caution. If I had it to so over again I'd be slow to treat with oil until most everything is glued in place.
Again, my apologies Lawrence for this diversion. Love the way you have helped voyeurs peer inside your boat!
