     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Thanks Peter. I’m looking forward to the crown, and the hatchet, I have to add to the Lion. A nice diversion from fairing the hull and planking!Hi Dean. Nice to see the steps how you made the coat of arms. With the constant quality!
And now realizing the new crown on the Lion. The example looks challenging. I wonder what creation you show us.
Thank you Heinrich! You never know…I am enjoying carving…lolDean you are just moving onto another planet. But ... I am so glad to have a friend who is so good at carving and painting ....nudge ... nudge... wink ... wink ...
That's a Lion on a King's Throne. That will become a eyecatcher on your NL!I removed the material for the slot…a lot to remove. For now I will stop, as the final adjustments for depth and width will come after the bowsprit is in place and the crown is on the Lion.
Plus there are additional pieces that go on each side of the keel, prior to planking. They are used in place of a rabbet, to terminate the hull planks.
What I have for now…
View attachment 270568View attachment 270569View attachment 270570View attachment 270571
Thank you Peter!That's a Lion on a King's Throne. That will become a eyecatcher on your NL!
Well that’s what I call craftsmanship , a masterpiece coming along, my compliments Dean !I removed the material for the slot…a lot to remove. For now I will stop, as the final adjustments for depth and width will come after the bowsprit is in place and the crown is on the Lion.
Thank you Robert! So much work ahead! I often don’t know what to work on next…lol.Well that’s what I call craftsmanship , a masterpiece coming along, my compliments Dean !
Excellent!Preparing for the crown.
It was time to remove the crown from the top of the Lion. Then blend the hair to replace the carved out area around it.
First I filed and sanded the crown down, close to the top of the head. Then I marked the diameter of the new crown ( I have to carve) at the base. Then started carving the extra material off.
View attachment 270367View attachment 270368
Then I blended the hair into the carved surfaces, to continue up to where the new crown will sit.
View attachment 270369View attachment 270370View attachment 270371
Then I painted the changed areas gold.
Thank you!Excellent!
Now, that is a fair amount of work to create sawdust by hand, steady and true. RichI’ve spent the last couple of days fairing the hull. I’m not even done with one side of the ship! I added some filler wood at the bow. I’ve been carving, filing, sanding, filing, and sanding!!! You get the idea! Still not done with the filler material on the bow. I’m starting to think the provided frame is too short…would not surprise me! If so, I have to add some wood to it. I will know once I sand enough to get the final shape.
Pic…
Greetings from Brooklyn, Mia Amigo.I’ve spent the last couple of days fairing the hull. I’m not even done with one side of the ship! I added some filler wood at the bow. I’ve been carving, filing, sanding, filing, and sanding!!! You get the idea! Still not done with the filler material on the bow. I’m starting to think the provided frame is too short…would not surprise me! If so, I have to add some wood to it. I will know once I sand enough to get the final shape.
Ahh and I thought your shipyard was idle. That is a cool workstation for your tools Dean. Did you make it?I’ve spent the last couple of days fairing the hull. I’m not even done with one side of the ship! I added some filler wood at the bow. I’ve been carving, filing, sanding, filing, and sanding!!! You get the idea! Still not done with the filler material on the bow. I’m starting to think the provided frame is too short…would not surprise me! If so, I have to add some wood to it. I will know once I sand enough to get the final shape.
Pic…
Thanks, I bought the workstation from MicroMark. I drilled extra holes in the storage area to the right for my files and bits.Ahh and I thought your shipyard was idle. That is a cool workstation for your tools Dean. Did you make it?
Thanks Jimsky. Those are good tips!Greetings from Brooklyn, Mia Amigo.
If I may, one of my recommendations while fairing the hull, is to use a long sanding block. Depending on the given bulkhead layout, it should cover at least 3 neighboring bulkheads. This will ensure an even fairing and avoid gaps. Also, use flat\even wooden block (1 ~ 1.5 inches wide) made out of plywood for example. Move this block only in one direction (not back & forth). Do NOT use any soft sanding blocks.
Nerve wrecking job. This is where the difference is made between failure and succes.I’ve spent the last couple of days fairing the hull. I’m not even done with one side of the ship! I added some filler wood at the bow. I’ve been carving, filing, sanding, filing, and sanding!!! You get the idea! Still not done with the filler material on the bow. I’m starting to think the provided frame is too short…would not surprise me! If so, I have to add some wood to it. I will know once I sand enough to get the final shape.
Pic…
