NORSKE LOVE - Billing Boats 1:75 scale
I decided to finish the cannon ports for all of the cannons on open decks. Then once I install the cat davit along with all railings and the final scroll, this side will be done and I will repeat everything on the other side.
So at mid ship, here are the instructions... which show you to cut the cannon port into the planking and put a horizontal board underneath to frame it....
And here is a reference pic from the kit pictures...
Obviously that isn't correct, so I decided to thicken the walls and plank them like the rest of the ship...
and I had to create beams to add the planks...
then I checked with the walkway that will go above it on the knees...
I have to finish framing the ports and this bulwark and then I can cut and file the cannon openings. The most important part is making sure the ports are equally spaced. ;) Then it will be painted red and I can add the waterway boards, I will make the holes for the eyes to attach the cannon rigging for later prior to adding the walkway above. The walkway has to be planked like the deck and stained, then the side boards added. Then I can do the scroll and add the final rails and boards, along with the cat davit, at the bow. Then this side will be done! A lot of work to get this far!
Some people say my work area is always clean...not when I am working... :P
Happy modeling!
View attachment 361582View attachment 361583
Some people say my work area is always clean...not when I am working... :p
Happy modeling!
Good morning Dean. So good. I love it when you change the kit to get things looking like they should be. Ha….that work bench is so tidy during construction. I often wonder if a persons shipyard reflects the quality of their ship;). Time to give mine a clean thenROTF. Cheers Grant
Thanks Grant! I dreaded doing that, but just couldn’t bring myself to make a cannon port that is a single plank wall! ;)
Dear Dean
Unfortunately I missed your impressive progress in the last month, I get the impression that you achieved a very impressive and beautiful progress while taking care of accuracy in details.
Well done friend Okay Thumbsup:)
