Moving the mast step
The covid cooties kept me down for a while and then the Admiral got it too, so we've spent the last couple of weeks taking care of one another with not much time (or energy) to visit the shipyard. Feeling better now, I thought I would attack the problem I mentioned in an earlier post.
The following photo from
Unimus shows that unlike Pavel's kit where the mast is stepped to the central frame, it is actually stepped one frame forward of the central frame.
So the question becomes, "What to do about it?" At the risk of waxing philosophical, people build models for many different reasons. Many are happy to assemble a kit simply for the pleasure of it, with no real thought to accuracy. Let's face it, 99.9% of the people admiring one of these models will be amazed at the intricacy and the effort it took to build. None of these people will ever notice that some blocks were rigged backwards or the stern decorations are not correct. There is not a single thing wrong with this.
Others will spend months or years researching their subject, scratch building their model exactly the way it was originally built, even in areas that no one will ever see. They agonize over the correct crest for the cannons for the time period of their subject. Few people would recognize or even appreciate this effort, but the modeler will know. There is absolutely nothing wrong with this approach either. We all take what we need from this hobby.
Most of us, I think, fall somewhere in the middle. We want to impart accuracy as best we can, purchasing aftermarket parts to replace poor quality kit parts and doing the best we can to make as realistic a model as is practical - for a hobby.
For the vast majority of the models we build, we really cannot be certain
exactly how our subjects looked. We rely on old, hard to read drawings, paintings and contracts to work out what they
might have looked like. Even for some of the popular subject that still exist - Victory, Constitution, etc., what they look like today does not reflect how they looked during the period we've chosen to model. It's frequently just a guessing game.
Oseberg is a ship that we can visit today and see how she was actually built because it never underwent the sometimes numerous renovations that other existing ships have. (Well, we can't look at it for a couple of years, because the museum is closed until 2027 for renovations.) We can know almost exactly what the hull looked like when she was buried. I fall into the category of modelers who want to represent the model as accurately as is practical for the areas that are visible to the viewer. Because of this, I chose to move the mast step forward one frame as it is in the real ship. Had I discovered this earlier, it would have been significantly easier to build the change in. Hindsight is 20/20, so one can only move forward.
After musing about how I would do this for way more hours than I care to admit, I finally arrived at a solution. I would simply slice off the very top of the central frame and transplant it one frame forward.
First, I made some stop-cuts in the
bitis to keep my blade from wandering.
Then, using a sharp utility knife, I pared away as much of the
biti where the mast step would be moved to as I could. Then I followed up with a sharp chisel to flatten it out.
I have a half-circle blade for my Fein oscillating tool and this gave me a ledge to support the back of the blade as I sliced the mast step
biti off the top of the central frame right at the floorboard ledge.
I cleaned up with a sanding stick to smooth and level the frames.
After cleaning up the bottom of the central frame, I glued a piece of cherry veneer on to make up for the material removed by the saw.
Using scrap from the leftover "sprues", I made a new extended floorboard ledge and a new biti for the central frame. I just left the original extended floor ledge in place. It will be covered by the floorboards and I didn't want to risk damaging anything trying to cut it out. Finally, I drilled holes in the central knees to match the other frames. The first backstay goes into the knee directly behind the mast step, so it was easier to drill this before the planking was finished. I say "easy", but the drill bit alone just barely fit between the frames, so to get a straight hole, I had to spin the drill bit between my fingers. Four cramps later, I had a couple of holes.
So after all that, no one but me or those I tell will ever know about this change. But I will know.
