Your experience is showing as you work through the various challenges without delay....
Good morning John. She is starting to come together beautifully. I love your metal work on the props, shafts and your rudder enlargement. Cheers GrantView attachment 439761
Next up was to make a stand I just used up some the wood I had around the workshop, the main thing to make sure of is that the stand is high enough so that the props and rudders are clear,
another view,
a look below, just a little bit of final adjustment needed, the edges of the frames will be padded tp protect the paint work,
and a couple of views sitting on the stand,
best regards john,
wonderful work, dear JohnView attachment 439761
another view,
best regards john,
Wow! Now that's a nice painted hull!
G'day Lee, I hope the following info helps you, I'm not very good at this sort of thing, I have a small set of plans also with a Photo book with some instructions and a build sequence I will send these to you through a PM or your email,
So from A to B, B is where the tube emerges from the hull and C is where it stops, I used 350mm tube shaft assemblies, but with adding the shaft support behind the tube I had to cut the length of the tube down so as to fit the support in place, I also used 55mm contra rotating propellers,
The green tape is where the transom ends, I put the twin rudders in line with the shafts,
I hope all this is clear enough I'm not too good at describing things,
hope this helps you,
best regards John,
PS I will scan the plans and instruction books tomorrow and send them to you.
Thank you so much that should help me out quite a bit it's more than what I know befor hand lol will just need to track down all the parts now eg props,shafts,shaft supports, some brushless motors lots to do lol. But thank you will look out for tge plans on email much appreciated buddyG'day Lee, I hope the following info helps you, I'm not very good at this sort of thing, I have a small set of plans also with a Photo book with some instructions and a build sequence I will send these to you through a PM or your email,
best regards John,
