This is really wonderful work Tobias! Thank you for sharing your build with us.
Hi Tobias. There is so much to see on the SOS. Why did I miss this build of yours?Nothing special, but I think it works well. I decided to leave out the tree nails in the upper area and also work with the bolts there where there are no gunports. According to GD, original bolts are also attached here and not tree nails. It says so in the monograph to facilitate the omissions.
Hello Peter, according to the plan, the direction is changed from frame 26, the frames are also mirrored.Hi Tobias. There is so much to see on the SOS. Why did I miss this build of yours?
Very nice work on your frames and the bolts. They are looking very smooth.
PS: Is it correct frame 25 is turned? It’s no problem, because its dry-fit.
Well, never to old to learn! Thanks for the explanation.this is typical and often on french ships
Hallo Tobias,Since we have very nice weather and the temperatures are still bearable at the moment, I have moved my workplace to the terrace. The program is: Marking the bolt holes.
There you have it really cozy, just a nice place to build.
