Oh yes, Marten, we are recovered and it was nice to just relax after two years of the pandemic.Hi Tobias,
Hope the dog enjoyed his holiday and you ofcourse as well.
Welcome back with fresh energy.
@Tobias, How did you color the bolts, before or after assembly, possible you can show, how to fix this, BDW, exciting building log you have, follow your records when they come, Regards Knut-
Dear Tobias,Day 2:
Measure the hole pattern of the frame exactly, mark, drill holes, insert bolts, file off bolts (first use a file, smooth with 240 grit sandpaper and then polish with abrasive wool), blacken bolts and then come the upper tree nails at the end.
Exactly in that order. Working time per frame about 1 hour. I've definitely been busy for a very long time.
If we now imagine the following:
You won't see half of it because it disappears under the planks and the other half will probably be cut away if I open the side, i.e. 3 frames then a whole one again, etc. But I know that they are there.
Well we'll see.
Thank you all again for all the likes and comments, you are a great support.
