- Mar 27, 2019
Yep that looks familiar.Here is my latest on HMS rattlesnakeView attachment 109621
Wow! Impressive "workaround"!Finished the transom over a couple of days work. The provided white metal carvings for the transom did not in the wildest imagination fit the footprint of the laser cut transom. What to do, what to do... I decided to cut the britannia metal transom carving into three pieces: carvings to the left and right, plus the rattlesnake. I trimed all the metal as close as I could get off the carvings and snake, put a base coat of black in all the hollows, then brown all over to simulate wood. Then gilded highlights on the actual carvings left and right and the entire rattlesnake.
After mounting the carvings, some trim for the windows (gilt), plastic in back of the windows (from a microwave popcorn bag) painted a dull white and trim around the bottom of the transom and around the upper curve painted black to match the rest of the transom. Still have to apply the photo etched "rattlesnake" lettersView attachment 104665View attachment 104666View attachment 104667View attachment 104672View attachment 104673View attachment 104675 once they arrive from Model Dockyard fittings.
OMG My son did listen to some of the things I told him.Just follow along, I'm trying to post step by step of what I'm doing. Bottom line is there will be mistakes but I'll let you in a little secret: only you will know where the mistakes are unless you specifically point them out. Just go slow and be resolved to spend an hour on something that should only take 30 minutes. Be a perfectionist. If you're not happy with how something came out, rip it out and do it over.
It's always SOMETHING that goes wrong. Fixing things is part of building.I had to fix part of the gun Port that's why I didn't send pictures
