Some pics of the cannon mounted on the carriages,
and the cannon that will go on the two upper decks,
and after triming the axles to size and painting,
these are for the second deck down,
@neptune ,Hello John, after you installed the lower deck in your gun carriages may I ask how you fastened thin to the ships decks, a couple of nails or a small wood screw or did you glue thin in place?
Regards Lawrence
@neptune ,
I just edited Lawrence last post, the question to you was not visible before....
Regards Lawrence
Hello John, Thanks for your great ideas, they are very helpful. Now I can start the task of building 24 gun carriages.G'day Lawrence, on the lower deck I glued them in place and also put a long pin down through the sides of the carriage, see pic below,
you can see the pin between the X,s, on the upper deck I will probably glue a small block of wood
under the carriage to fix it with glue to the deck,
best regards John,
Hi John,
I missed your post about fabricating the decorative fretwork.
Can you run us through your process please ? It looks great.
