Santiago de Compostela-Disar Model 1:72
While waiting for the wood strips to arrive I was looking ahead in the instructions and am curious about the cannons. They are unlike any I have seen before.View attachment 265868
Quick research via Google showed me that these may represent the older breech loaded cannon. I've been around firearms my entire life and am familiar with what a breech loaded weapon is, but these cannon are new to me. I'm unable to find much information on them, can anyone help me by providing more information?
Thank you for looking,
Glenn
Hi Stan. Please let me check my sources and I’ll tell you something soon....
Greetings
Some pictures of my progress. I am tapering the planking at the Bow only so far, may need to start to also taper towards the stern as well.
I was attempting to plank without any nails, but was unable to properly clamp it up. I am removing the nails once the glue dries. This is a single plank model, I'll figure out the finish as I go along. Wetting the wood around the holes after the nail is removed helps close them up, but not completely. I'll try various methods to fill them when the time comes-I've plenty of cutoffs to experiment on.
So far no heat has been used, only soaking the planks in water prior to shaping and installing. I've only used PVA, this is why progress has been so slow-often a single plank in the evening after I get off work.
It's not perfect but for my first planking job I'm happy with the way it is progressing.
Glenn
Hi Glen. Looking good. I’m also on my first real ship and have also taken the approach to just attempt a good model. My only advice is that it is your ship build it as such and enjoy it. Cheers Grant
Time for some pics.
The next pics show what I was talking about previously, the thickness between the inner and outer panels that make up the bulwarks (hope I'm using the correct terminology). AoS was quick to ship the strips I ordered (ordered Sunday received Wednesday) so I'm starting on the top rails next.
As always comments, suggestions and critiques are very welcome.
Thanks for taking the time to look!
Glenn
Awesome build- I’m enjoying your work
A few pics adding a top rails while it was clamped in place.
The clamps came in a watchmaking tool lot I got from Ebay. I'm not a watchmaker but the tools have been useful for some of my various hobbies. The machinists clamps came in a machine tool lot, again Ebay.
Next some pics of the toprails in place before shaping with sandpaper and cleanup with rifflers.
Glenn
The toprails are made of lime wood I purchased from Jason at Ages of Sail. This is what he recommended when I needed more boxwood strips to replace what I had broken from the kit. The toprails are 1.5 x 8 mm.
I have to say this limewood is great to work with compared to the boxwood included in the kit. The boxwood is larger grained, easy to dent and brittle when bending. The lime wood is tight grained, harder to dent yet easily bent.
This is after a couple of hours soaking in room temperature water and no heat:
Overnight to dry with little to no springback when removed.
Had I known this limewood was so forgiving before I probably would have spent the $15 and ordered it along with the kit when I purchased it.
Here is after shaping the toprails.
Due to the varying width I had a choice of keeping the width of the top rail constant, or keeping the overhang constant. I chose to keep the overhang constant, matching the 1.5mm thickness of the wales.
Thank you for looking and all of the likes.
Glenn
