OMG that ship looks incredible! Quick fix on those light leaks, glue some black construction paper to the interior surfaces of the planking. Fast and easy as long as you still have access to the inside.
Must be reverse angle pictures with bowsprit on port side and then on starboard. Beautiful ship in the making!Lastly fixed the beakhead deck errors as well as replacing all other out of scale/non matching grids - now all 1mm throughout all decks.
View attachment 327907View attachment 327908View attachment 327909View attachment 327910View attachment 327911View attachment 327912
May I ask where the ships wheel is located?
Paul, Grant, Greg, Jack, Daniel, Kurt - thanks so much for your very kind posts
Nigel,
Yes indeed – the idea of lights hit me in the face just after I installed the back side of the outer windows. I did not think that they (all the windows) would SO “blacken out” all interior details. I have been “obsessing” with this for a week or so. I am so tempted to in-fact remove the last upper cover plate to regain access to the two floors as well as the inner gallery decks.
View attachment 356389View attachment 356390View attachment 356391
I did see the youtube video of the Soleil along with lighting, and their lighting kit. It won’t work for this application in that it requires AA or AAA batteries.
The solution will be for me to again purchase LED’s from Evan Designs ( a sponsor here as SoS) as I did for my Santisima cross section. His lights require a small flat battery as well as incorporating a small on/off switch. Santisima below (entire build log is here at SoS). He also has a blinking option also available..
View attachment 356398View attachment 356399View attachment 356400View attachment 356401
TBD – I will order lights and add needed inner seals. I don’t think that for this build I will construct lantern housings –but, I do want to also light the inner balconies as well as the upper and lower officer quarters. Fun,fun,fun,….
That said the elephant left in the room are five of these lanterns YIKES hahaha… Found here – on youtube ---- really nice work.
Cheers,
There was no wheel with ropes and pulley running to the tiller. In the early 17th century and before, ships were steered with a whipstaff. The helmsman operated it from under the halfdeck or from a room on a sublevel below the main deck or upper gun deck. The helmsman could often look forward out portals across the main deck to hear orders from officers above, or if the helm is located too deep within the ship, orders were relayed down to the helmsman.May I ask where the ships wheel is located? It must be below deck.
Angus' book is more historical background, not construction details helpful for a modeler like Sephton's book is. By the way, McKay has the rudder tiller on the wrong deck, as is the whipstaff. Don't follow that example. He really should have researched details like that before writing his book. Always question his information before you use it. A lot of it is good, even great, but some truly basic things are not, and some of those errors are carried over from his sources. Even John Payne, Willem Van de Velde and Peter Lely have errors that need to be spotted and avoided.Kurt,
hahaha you just beat me to it - I was putting together some images from the McKay book and images of the Vasa - Dutch but less than a decade apart.
PS: Awesome work on your Sovereign - your work really captured the mechanism indeed - thanks for your post
PS: I don't have the James Sephton book - Do however have one from Angus Konstam - will look for your suggestion....
View attachment 356555View attachment 356556View attachment 356557View attachment 356558View attachment 356559
Novice am I.Wheels were not in use until 18th century.
Good morning. Man they cramped the crew into this space. I wonder what the degree of leverage was with this system. I imagine the helmsman must have been a fairly robust and fit individual. This is not a small vessel. Cheers GrantThere was no wheel with ropes and pulley running to the tiller. In the early 17th century and before, ships were steered with a whipstaff. The helmsman operated it from under the halfdeck or from a room on a sublevel below the main deck or upper gun deck. The helmsman could often look forward out portals across the main deck to hear orders from officers above, or if the helm is located too deep within the ship, orders were relayed down to the helmsman.
From zu Mondfeld:
Working whipstaff on model of HMS Sovereign of the Seas. The Sovereign is probably the largest ship capable of being controlled using a whipstaff. The ships wheel has many advantages over the whipstaff, foremost being the ease of which a heavy rudder under great force can be positioned and held. It probably took more than one person to hold the whipstaff with the rudder at extreme angles if heavy seas.
The tiller protrudes from the transom, and will be incorporated into the rudder later in the build. The tiller and whipstaff are positioned "hard to larboard".
You won't be after you use this forum as a reference and build one model. Five years ago I was the novice asking the same questions.Novice am I.
Hi Kurt,Angus' book is more historical background, not construction details helpful for a modeler like Sephton's book is. By the way, McKay has the rudder tiller on the wrong deck, as is the whipstaff. Don't follow that example. He really should have researched details like that before writing his book. Always question his information before you use it. A lot of it is good, even great, but some truly basic things are not, and some of those errors are carried over from his sources. Even John Payne, Willem Van de Velde and Peter Lely have errors that need to be spotted and avoided.
I believe that the tiller location as shown in the Peter Lely painting, and subsequently McKay's interpretation, is incorrect based on the following:Hi Kurt,
Why do you think mckay put the tiller on the wrong deck. I know there is debate about that but it is the same spot as where the Lely painting shows it. On the second gun deck.
I have never found a clear explanation why that would be the wrong deck? It would actually bring the helmsman closer to the hald deck from where the orders were given, sounds logical to me. Just curious.
