Hello All
First update
I spray paint the black and peeled the liquid mask
The results are so and so , with a flaky limit between the colours
I will have to retouch a bit
Daniel
Hello All
After a long time I did the painting of the hull .
Now I have to do some touch up here and there but this is it.
Hoping that in the next weeks to glue the aft cabin and get on with the model
Daniel
G'day Daniel, when I worked in the shipyard you should have seen the Frigates we built for the Royal Navy in there different stages of construction, and then the finished ship as she slid down the weighs, looked like two different ships, yours will be Ship Shape and Bristol Fashion,
Hello All
Today is Romania Day
SO I worked a bit at my ship
Fist thing was to mitigate a little wobble of the pulley that is attached to the propeller axe
Bought an cnc fixture but no much improuvement
And last I build the cover of the rudder part .
Daniel
Hello ALl
Last update for today
I put the strips on the aft section and because I have only pear wood I did an contrast with yellow and red pear
Sadly white hornbeam is finished and with the war going
Bibigon is unreacheble from my place .
The aft cabin will have roof in yellow pear too so no big deal
Daniel the war
Hello All
Today is a rainy day so I worked a little bit at my model
I found a place for the receiver and the on off switch
The wobble of the engine is still present so I have to find an alternative solution
I bought a new axe and will find an new solution for transmission
Also I have to find a place for the servo
Daniel
Hello All
Today was organized a Hobby fair for the youg and children
I was invited to represent the shipbuilding guild and I participated with my son model - bluenose and my janet
The children was very happy with janet because was unfinished and could see the electronics inside
An I found some aero modellers in my town.
Very happy to participate and show some models
Daniel
Hello All
I finnaly have some time to modify the transmission on my Janet
Hope to finish with the wobble
I ordered some pulleys from germany and surprise , even germans are not so precise as told or I got one tough luck
the 12 teeth pulley is 5 mm bore and my propeller shaft is 4 mm bore
Glad to order a 16 teeth 4 mm bore to replace the 12
but the belt is shorter so I had to make adjustement on the motor position
I reach a solution that help remove the motor from cabin . and tomorrow will try to see if it-s working proprely
Daniel
Hello All
In the hope to glue la aft cabin I work on servo position
After some position where it stay in the way of different pieces I reach a conclusion
I will put under a bench in the aft and will ve a lost servo ( will can not be moved after gluing the cabin)
I am ok with this conclusion and now I did some dry fitting
Wili have to glue with epoxy resin
Any Advice ?
Daniel
Hello All
Today I have the servo glued in place and in the afternoon will begin the cabin fixing in place
That depend on admiral and home chore list
But I have hope to do it in the sneaky way in this chrismas madness .
Daniel
Hello All And Merry chrismas !
This is my ship after gluing the cabin
Have to sand a bit some protusions but no biggie
I am Very happy today ,I waited for a long time and finaly I got no vibration from the motor and transmission.
Daniel
Hello All
Yesterday I made a little deviation from original , I was puting a skylight on the aft cabin roof.
Projected the pieces and cut them ,now I was dry fitted them .
The reasoning is I have to exhaust the air from first cabin that cooled the esc
so the skylight will have a mobile part
Also the roof is big and is a little bit empty
This is the first try at roof structure
Daniel
Hello Heinrich , Glad to hear from you
I wanted to finish the ,model this winter and it progresses well
Glad to finaly have no vibration due to transmission -that was keeped me in place
Daniel
