? Are you serious.
By the way, young woman were referred to as "bints" in 40's and 50's (Arabic/soldiers returning from middle east service) and "birds" in my youth (1960's). A "dolly bird" was very complimentary-It is one of the 'urban' dictionary definitions...not mine![]()
Maybe a (or some) photos of the drawings are making it more clear, where you (or the drawings) have the problem. The attached photo is not helping (for me in the moment) to understand#G
Fore of pair -scarph joint-will be shortened to be under the port.
Aft-with toptimber-also shifted foreward and with motises for sill foreward and mortises for sweep ports aft.
Not worked on ship for a couple of days and when rechecking height of sills, some discrepancy between port and starboard is noted. Frames J and H tilted and reset
Further confusion. On my (not so clear) framing plan, there seems to be a variation in size of ports (by height) and the sweep ports do not measure as square-3.5mmwide and 4.2 high.
CAN SOMEONE PLEASE HELP AND CLARIFY THIS.
Thank youHi Stuart,
Just saw your log over here on SOS.
IMO - keep your ports square as you can, the drawings have some “ instability” in them, and you have to “notch” into or “shift/cast” the frames around them to get them right.sweep port lower cills follow the curve line of the lower cills for the gun ports.
just make sure all ports are the same height, length and position port/starboard or your model will look oddly offset.
sorry I have not been much help to you, I have not been spending much time modeling in the past year, I will try and be around more in the future.
Too true. Tried to minimise by using cut bands held by clamp.Oh, and watch out using rubber bands to hold frames in place, they can also pull the frames in funny positions if they are not perfectly straight and not too tight.
