When it comes to that stage in the build. I like to fix the deck then plank afterwardsSome advise needed from the audience ......
Gentlemen, I have a question.
I will soon start with the planking of the main gun deck.
The manual suggest to plank this deck before fixing (pinning) into the Hull.
Why?
I would prefer to first fit the gun deck into place, glue it and afterwards staring the planking.
And the whole deck at once, not leaving the middle section empty as mentioned in the instruction manual.
My preference?
Leave enough material of the Balsa, so that youPreparing the Hull for Planking.....with BALSA wood...
I meanwhile added in the stern-part and front some wood (BALSA). This will allow me to better fix the lime wood strips...at the most challenging curves...
It's a hell of a job, but, worth the time.
Next I will sand the bulkheads....
Hallo Marc alias @HMSFlyHello Everybody,
I'm since +- 2 weeks member and in this context I would like to actively participate in the group.
Yesterday, I received the kit and the upgrade kit.
It is my intention to honestly write my experience and activities, and will post on a regular base photo's and comments.
I learned a lot from already existing blogs (zie NOMAD) and I will try to achieve the same level.
It is now my third ship:
- Artensia Latina Virginia (first small kit)
- I finished a month ago the Occre's Endeavour.
I consider this kit as a last big step in my learning process: after the FLY I will build a "big" one like The HMS DIANA or other.
So, I hope you enjoy my pictures.
Marc
Splitting like that I have seen become more and more common when the framing is made of MDF boards. You might want to pre drill your holes for nailing might help prevent that from happening. And you can pull the nails out and you frames should go back to normal or you can fill the very small gap with CA glue and recoat with paint.gentlemen,
I would like to receive some advice:
I used the supplied nails to attach the gun-port strips. While carefully hammering this in, I discovered to my amazement that the bulk warks (ie the wooden supports) simply burst! See first photo. What did I wrong? And this happend several times......???????????
Does anyone have the same experience?
In the meantime I have decided not to remove the nails to prevent worse. I simply filed off the cups carefully.
On the other hand, I thought it would be a good idea to fix the inner walls completely with walnut strips. Nice and finished result, and, I also strengthen the gunport strip.
So please be welcome!
Marc
