The Donald David, a Maine Lobster Boat, launched 1956
Attached photo is of the first strip of wood about to be glued to the hull. There will be a total of six strips on each side of the hull; they will be the walkway that reaches stem to stern on each side. The strips are a mixture of light & dark wood and will be a mix of dark/light pieces to clearly show the distinct pattern of alternating dark/light strips the whole length. The strip attached to the hull, on each side, is tapered along its entire length so that the group of strips will lay nearly flat rather than follow the tilted angle of the hull. It's a lot of fussy work but I am trying my best to accurately represent the real boat, The Donald David.
Happy Modeling.
Steven
Attached photos are latest photos of the deck strips from stem to stern. There will be 6 strips attached to the hull on the inner surface of each side of the hull. At
the moment there are 2 more strips to apply on the port side and 1 strip to apply to the starboard side. I was worried that there might be problems attaching these strips, but it has gone very well so far.
Happy modeling
Steven
A few days ago I was reading an note in this site and the author commented about limited info regarding building small, ships boats that could be mounted on a ship model. I found 5 paperback books in my files ; 4 about building small boats and one about scrollsaw techniques which has helpful information that would be useful to to anyone planning to make small ships boats.
I have photographed the magazine covers and index page from each of these 5 books and I am posting those photos for all who may want to seek out those sources of info.
I now have the deck strips in place along the entire length of both sides. I was actually worried that these planks would be troublesome to install, but they went in quite well. Next part is to make & install the cabin wall so I can begin making and installing a removable foredeck. Also, I need to buy a complete operating system for propeller, rudder and lights. Ideas & recommendations would be greatly appreciated!
Hi Steve,
Your boat is coming along nicely.
Looking back at older posts your boat is around 25" long.
Have you used or owned and setup RC gear before?
I would suggest for low cost, and modest performance a 385 brushed motor or for more grunt a 545 brushed motor.
Be sure to get the 385 or 545 and not the 380 or 540 as these are high performance motors where as the 385 and 545 are high torque motors.
If you want to go brushless I would recommend an out runner.
You will also need a speed controller for the motor, a servo for the rudder and if you want lights to be turned on and off from the radio control set then you will need a RC switch.
As for the radio control set there are now a bewildering number of manufactures, both of my radios are Chinese and I have had them for quite a few years without problem. My main radio is a Frsky but there are other equally good sets available at reasonable prices.
For battery's I would stick to Nimh chemistry.
This is only a general idea.
If there aren't many good hobby shops in your area then online is good. I have found Alli Express and Banggood to be pretty good, there is eBay as well, the main thing to look at is reviews of the seller.
Cheers,
Stephen.
Thank you for the information Stephen. It is very much appreciated. I have no equipment for my boat yet, except for one OLD motor to operate the rudder. I will be buying all new equipment for this boat, I haven't looked into hobby shops yet. We moved from North Carolina to Wisconsin about 8 months ago and looking for boat modeling stores slowly rising on my To-Do list. I did find info about Wisconsin Scale Boating Association, just south of Milwaukee WI, which is about 2 or 3 hour drive, south of Neenah Wisconsin where I now live.
Again, thanks for your kind assistance.
