Not yet, right now it's still in 2-D.Wow! This build is in 3-D !
Hi Daniel. Nice to see that you have started with the final placement of the frames. They look neat and you have mastered a working method. You will enjoy watching the shape of the hull grows frame by frame.Good morning,
Once again not much to show however there is still progress happening here. I now only have 14 more frames to punch out and glue up. I cut out the center portion of the jig leaving a small shelf for the rib extensions to sit on.
I have considered several ways gluing the frames onto the keel and with the exception of the first 5 or 6 frames, there is enough flex in the frame extensions to insert first into the keel then rotate down onto the jig and open the extensions into the jig slots. I would first have to temp fix the keel assembly accurately over and in line with the jig where it cannot move then proceed with the frame installations. I have checked (dry fitted) each frames slots (and jig slots) for fit onto the keel/jig with just enough filing to get a good tight fit without having to force anything.
I will end up gluing all ribs to the keel before applying any poly stain finish. So that's where I'm at so far and hope you all enjoy this short update. Thanks for checking in and happy modeling!
Nice assembly approach, Daniel. This may work handsomely.Good morning,
Thanks Peter, It's all just sanding till your blue in the face.Hi Daniel. Nice to see that you have started with the final placement of the frames. They look neat and you have mastered a working method. You will enjoy watching the shape of the hull grows frame by frame.
Thanks Johan, the only other practical way I can think of is dropping them in through the jig, but it would be way more complicated calling for an elevated jig. The secret will be holding the keel solid tight in its inverted position which I believe I can do.Nice assembly approach, Daniel. This may work handsomely.
I used an elevated jig, dropping the frames from above onto the keel. With a little tweaking I got the frame ends into the jig, thus securing the frame. I started off with installing like three frames spread out over the keel and worked my way towards frame 31.Thanks Johan, the only other practical way I can think of is dropping them in through the jig, but it would be way more complicated calling for an elevated jig. The secret will be holding the keel solid tight in its inverted position which I believe I can do.
Looks amazing detailed model, i will follow your work logs.Good morning,
I will definitely do one more dry fit with all the frames and try to establish where any major problems may occur. I suspect there will be some vertical challenges to deal with due to the keel not seating well between adjacent frames, hopefully this will reveal itself in a dry mockup. I'm hoping to hold longitudinal alignment with a few lateral braces along the length of the keel.the keel might "meander" a little bit around a theoretical centerline.
The keel won't give you much issues in the vertical plane, the more though from your frames. But, the more accurate you've done all your frame dry-fitting, the less issues you'll find.I will definitely do one more dry fit with all the frames and try to establish where any major problems may occur. I suspect there will be some vertical challenges to deal with due to the keel not seating well between adjacent frames, hopefully this will reveal itself in a dry mockup. I'm hoping to hold longitudinal alignment with a few lateral braces along the length of the keel.
Hi John, I'm glad you found my build log, looking forward to any comments you may have.Daniel,
Ok. now I know where you were hiding. I'll go back to go through your log. Looking to be a nice super detailed kit. I kept looking in wood kits forums...
Re; my PM from a couple of weeks ago - forget it - will stay active with your log.
Regards,
Hello Estis, I'm delighted to have you aboard, hope you enjoy.Looks amazing detailed model, i will follow your work logs.
Regards and good luck .
Yup, we all have Heinrich’s problem, “Sanding Elbow”.Thanks Peter, It's all just sanding till your blue in the face.![]()
