Titanic 1/350 MiniCraft Kit build
Trial and error:
I didn't like the kit details for the docking bridge. So I gave a try at scratch building the engine room telegraghs and I think it is a binnacle. I made the bodies of the telegraphs from brass rod. The ends were punched out of thin styrene sheet and painted MM Acyrl brass. The levers were made from scrap PE railing. I can't count the number of times these things jumped out from between my tweezers and I had to go hunting for them. and in the end, all for naught.titanic 420.JPG
When I added them to the bridge they just didn't look right. Way too large.
So back to the drawing board. These are much smaller and simpler. I made these telegraphs from Evergreen styrene rods. The piece on the left is one of the original kit telegraphs. I decided it looked better as the (call box?) behind the ships wheel
when I started looking at how to do the posts on the underneath side of the bridge I decided it made more sense to do them in one continuous pieces. I scrapped the short posts above and drilled holes in the bridge to accommodate the full length posts.
I removed the telegraphs and ships wheel from the short posts and re-added them to the new posts. I enclosed the stairway because I saw that "Art" did that on his build. the original location for the kit stairway was a couple of feet to starboard. I moved it to line up with the rectangular deck support. That places the bottom of the steps too close to the capstan. not sure what is out of place but it is what it is.
Compass platform with kit binnacle. I added the little spheres to either side. I think this is also way too large but not so obvious as the stuff on the docking bridge. The spheres on the binnacles are water softener resin beads. I saved some of it when I installed a new water softener - don't ask me why! But I finally found a use for it!
had to scratch build these buildings. The instructions made no reference to them at all! The picture on the box shows wenches in these locations. I saw buildings on other build sites so that is what I did also.
Haven't been modelling for awhile, fell over a wheelbarrow full of earth and fractured a vertebrae in my back. Your model is very well done!
Ouch! Hope you get to feeling better. I fall down a lot but I guess I bounce pretty good. No injuries so far
I started the boat davits the other night. After about an hour of trying to glue just the first few pieces together only to have 2 of them fall off later I promptly placed an order for the GMM 350-19 davit set!
life is too short to to deal with this aggravation.
They say you get what you pay for but in the case of these davits you don't. ~$18 wasted
I received my GMM boat davits from VCShobbies. They actually arrived 3 days early. That was nice surprise. These are in my opinion much superior to what I was trying to use before. I still have to grind out 20+ of these things!
The GMM davits look much better. For my build I think I'll still have to order the Tom's Modelwoks davits to get the Lifeboat ropes even if I use the GMM davits.
you might want to read Art Braunschweiger's comments about the lifeboat ropes. I DID use them on mine however. Seems there were some other pieces I used from that set.
It looks great awesome job im building one for a client of mine just did the wooden decks
So what is the final result of this project ?
It’s been sitting idle on the build table for something like 3 years. I just finished a 1/48 TBF Avenger that had been sitting for 6 years! I’m going to dust this off in the next few days and see about finishing it off. Thanks for your interest
Thanks for waking me up on this project. I’m motivated now to get back to it! If I remember correctly I got discouraged scratch building life boat chocks. I think I am in a better frame of mind to tackle them now
The wood decks were very intimidating at first but actually went down very easy. I used Gorilla glue on mine. That’s what was recommended by the maker if I’m remembering correctly. It’s all coming back now. I didn’t like my placement of the stern railing also. As you can see it doesn’t take much to derail me!
I hope u do finished it all was going well im doing a late great titanic model now just started
