Love this deck! It really adds to the scale. Great job, Nathan.
it's looks very impressive and beautiful progress, well doneWell I thought it would be straight forward and fun to attach all the various bits 'n' bobs on the upper decks. Wrong! I don't know if the instructions were wrong or I got some of the pieces mixed up but the bases of some of the funnels didn't seem to fit into the deck outlines while maintaining the proper orientation of the funnels. The two below in red had to be cut and turned 180 and 90 degrees respectively.
View attachment 209064View attachment 209065
I switched the two in green below because they seemed to fit/look better. I seem to recall it not being clear which part # on the trees matched up to the correct part. That may be part of my issue. I used Art Braunschweiger build as a reference and came to the conclusion that the kit wasn't really close to being accurate. So I just put them on the way I felt made the most sense with what I had.
View attachment 209067View attachment 209068
thanks for your kind words. I just hope those viewing can use this to do better and maybe avoid some of the trouble I have had.it's looks very impressive and beautiful progress, well done![]()
That's awesome! The funnels look great.I got the funnels attached. Now I can start to add all those little detail parts to the decks.
View attachment 207630View attachment 207631
The main parts that were warped for me were the promonade walls. They were warped from the get go. I did remove them way before gluing them to the deck.The biggest problem I have with this kit is warpage, fitting things together.
Did you leave the parts on the sprues till you were to use them?
Thank you! I only hope viewers find it helpful. Not only what to do but just as important - what not to do!Hi Nathan, I found your build and this forum today while researching the Minicraft 1/350 Titanic.
Your build is looking great and I've already learned a few things from reading your posts. I can't wait to see more progress.
Which photo etch bending tool did you get?I was looking at the kit provided railings and using them as patterns. I finished the benches too. It was a good thing I got the etching bender tool from the Small Company. There were some for less online but they were made in China so I went with the Small Company.
Not only is this kit warped badly, the directions could have been better. Those for the PE were terribly hard to read.
Not really satisfied with this kit. I do think it had to have been stored near a heat source to be so badly warped. I hope the end result is as good as yours.
The railings look great.another rail formed according to the "pattern"
Same rail position. I bent to fit location on the ship, which after reading ( and reading and reading ) thru the instructions is what they intend for you to do. Still puzzled over those patterns on pages 26 - 28. I was fretting over doing the rails but once I got started they aren't that bad to work with.
It is the Mission Models EtchMate 3C. One note about bending long railings: It is fine for making bends near the ends (1/2 inch) but when you get towards the middle you can't really use the tool (in my experience) as the parts can't be slid that far under the gripping part. I resort to a small metal flat edge and a razor blade for those. The tool came with some thin plastic shims to fold the parts but I lost them and use a stanley utility knife blade for thatWhich photo etch bending tool did you got?
