Titanic 1/350 MiniCraft Kit build
Well I thought it would be straight forward and fun to attach all the various bits 'n' bobs on the upper decks. Wrong! I don't know if the instructions were wrong or I got some of the pieces mixed up but the bases of some of the funnels didn't seem to fit into the deck outlines while maintaining the proper orientation of the funnels. The two below in red had to be cut and turned 180 and 90 degrees respectively.
I switched the two in green below because they seemed to fit/look better. I seem to recall it not being clear which part # on the trees matched up to the correct part. That may be part of my issue. I used Art Braunschweiger build as a reference and came to the conclusion that the kit wasn't really close to being accurate. So I just put them on the way I felt made the most sense with what I had.
View attachment 209064View attachment 209065
View attachment 209067View attachment 209068
it's looks very impressive and beautiful progress, well done :) Thumbsup
The biggest problem I have with this kit is warpage, fitting things together.
Did you leave the parts on the sprues till you were to use them?
The main parts that were warped for me were the promonade walls. They were warped from the get go. I did remove them way before gluing them to the deck.
The promenade deck isn't flat, it's warped. Fiddling with the warped decks slowed everything down. The promenade decks were a real trial to fit. Even the boat deck is warped.
Nothing seems to come easy with this build. I tried gluing these skylights to the deck but the glue flowed up and covered the openings before I could place them on the decks. That ended up ruining my window opening on the white one. I had to remove window material and redo. I ended up making small blocks out of sheet styrene that I could attach to the deck and then, in turn attach the skylights to. I painted them dark gray so they wouldn't show thru as white.
picture showing block in place and one skylight in place
both central skylights in place
Fore deck skylight. Still need to add window maker to openings
If someone knows of a better way to do this I would be curious to know. Sometimes you just have to do it in a way that matches with your particular skills.
This is as you indicate, a trial and error model. There are a lot of "Oops" and "Oh ohs" involved, including the directions. For instance the directions on page 54 showing the hull painting, should be on page 2, eliminating some of the hull guess work.
Hi Nathan, I found your build and this forum today while researching the Minicraft 1/350 Titanic.
Your build is looking great and I've already learned a few things from reading your posts. I can't wait to see more progress.
Thank you! I only hope viewers find it helpful. Not only what to do but just as important - what not to do!
I mistakenly used these patterns to make my first couple rails.
Not a good fit!
The instructions with the PE were not much help either! I have yet been able to crack their code. Page 13 I get but what is 16 # 30 ?
There are no single bar rails on that page.
another rail formed according to the "pattern"
Same rail position. I bent to fit location on the ship, which after reading ( and reading and reading ) thru the instructions is what they intend for you to do. Still puzzled over those patterns on pages 26 - 28. I was fretting over doing the rails but once I got started they aren't that bad to work with.
I was looking at the kit provided railings and using them as patterns. I finished the benches too. It was a good thing I got the etching bender tool from the Small Company. There were some for less online but they were made in China so I went with the Small Company.
Not only is this kit warped badly, the directions could have been better. Those for the PE were terribly hard to read.
Not really satisfied with this kit. I do think it had to have been stored near a heat source to be so badly warped. I hope the end result is as good as yours.
Which photo etch bending tool did you get?
The railings look great.
Which photo etch bending tool did you got?
It is the Mission Models EtchMate 3C. One note about bending long railings: It is fine for making bends near the ends (1/2 inch) but when you get towards the middle you can't really use the tool (in my experience) as the parts can't be slid that far under the gripping part. I resort to a small metal flat edge and a razor blade for those. The tool came with some thin plastic shims to fold the parts but I lost them and use a stanley utility knife blade for that
